Digital Art Zone
CReate image Map
Posted: 17 January 2013 10:54 AM   [ Ignore ]
New Member
Joined  2012-12-03
I opened a blank 3D model with Daz 4.5 and went through using the editor to customize each part and now I need to know how to export an image map. The model is only edited with colors for each part, there are no images used in the customization, I do this to mark out each piece.
Profile
Posted: 17 January 2013 01:38 PM   [ Ignore ]   [ # 1 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
You can save thee settings, as a material preset for the colours for example, so that you can reapply them - is that what you want?
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 18 January 2013 10:59 AM   [ Ignore ]   [ # 2 ]
New Member
Joined  2012-12-03
Not so much, I want to make this editable with other programs so I can share it when I am finished with it. I need to know how to export all the color setting and whatnot as an image map
Profile
Posted: 18 January 2013 11:22 AM   [ Ignore ]   [ # 3 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
That Requires a UV map, then the UV map is the template used to add the colors and details on. That then becomes the Texture Map that loads in the Diffuse Channel in Surfaces.
 Signature
My art on DeviantArt and my Project The Primitives a year in the life.
Father of the Stupid threads, find the Stupid you need here.
I may not be worth much but most people tell me my two cents were well spent
Profile
Posted: 18 January 2013 02:56 PM   [ Ignore ]   [ # 4 ]
Addict
Avatar
RankRankRankRank
Joined  2011-12-10
IF (and only IF) the model has a UVMap, what you can do is colour your material zones, and BAKE the shader, take that into Photopoop, PaintShopPro or GIMP and edit it…
you will find the SHADER BAKER on the Surfaces Tab.  From what I read in your post, it seems that’s what you are trying to do.
 Signature
My DeviantArt Galleries
My ShareCG Gallery
OPENSUBDIV Testing and Discussion
3Delight Surface and Lighting Thread
Profile
