Digital Art Zone
Come On Down - Collisions for DS4.5 (mcjCollider)
Posted: 17 January 2013 04:27 AM   [ Ignore ]
Member
Avatar
Rank
Joined  2007-05-08
This is the upgraded version of SITC - Collisions. When rewritting this for DAZ4.5 I felt the script would be more powerful if you could select what you want to collide with the selected item(s).
You will need to install mCasual’s new mcjCollider plugin for DS4.5 .
With this version you no longer need to manually load/activate mcjCollider, the script will do all of that for you now. All you need to do is load your items (Send In Clones really helps to load multiple items wink ); Select the ‘collidee’; and then run the script. In the script you will select what item(s) you want, from a list of all the items, and then click on the ‘Collide’ button. Note: The collidee will not show up in the list, so that you don’t accidentally select it.
Link to Down:
Image Attachments
Profile
Posted: 17 January 2013 06:05 AM   [ Ignore ]   [ # 1 ]
Active Member
Avatar
RankRank
Joined  2008-09-17
Repeating what I said in the other thread; AWESOME!!!  Can’t wait to try it out.
 Signature
Resistance is futile.  You will be DAZzimilated
Old post count: 5719
Profile
Posted: 17 January 2013 07:03 AM   [ Ignore ]   [ # 2 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
Sweet stuff. Thx DraagonStorm, casual and Daz3D…love the plug btw…too funny.
 Signature
Pete
Community Volunteer:
If by some miracle I express an opinion then it is my own and not that of Digital Art Zone.
Somethings to Consider when starting to learn CG
My Render Thread
Proud member of the Bald Wizards Club
Profile
Posted: 17 January 2013 07:40 AM   [ Ignore ]   [ # 3 ]
Active Member
Avatar
RankRank
Joined  2007-12-07
This needs playing with! smile
 Signature
Some writings by a friend:
http://www.lizardsofthehost.co.uk/11.html
http://www.lizardsofthehost.co.uk/13.html
http://www.lizardsofthehost.co.uk/7.html
Profile
Posted: 19 January 2013 02:14 AM   [ Ignore ]   [ # 4 ]
Active Member
Avatar
RankRank
Joined  2007-01-05
Must absolutely see this,
Profile
Posted: 19 January 2013 05:15 PM   [ Ignore ]   [ # 5 ]
Member
Avatar
Rank
Joined  2009-04-30
Is is maybe possible to expalin the script with a few more pictures? I must say, that i don’t have understand this collide-tool. Maybe you can show it on some pics, what happens when I don’t use the script and what happens with the tool. It’s just a suggestion and it’s your choice, if you want to descrbe the script more or not. Thanks in advance.
Profile
Posted: 19 January 2013 07:43 PM   [ Ignore ]   [ # 6 ]
Member
Avatar
Rank
Joined  2007-05-08
The promo picture shows the before and after…
Top of the promo is a set of stairs with a bunch of rocks up in the air. I loaded the stairs, and then used Send In The Clones DS4 Pro to load up the rocks.
Under that is the after….. a set of stairs with a bunch of rocks up and down the stairs.
In between is where you use the script.
Steps:
1) Load a bunch of stuff into your scene.
2) Select what item in that scene is to be your collidee (ie: the stairs, or a rolling hills landscape)
3) Run script to select from the list what items you want to collide with the collidee. (ie: the bunch of rocks, or maybe a bunch of trees and flowers)
4) After you have selected what items are to collide with the collidee. Click on the ‘Collide’ button.
And that’s it.
Profile
Posted: 20 January 2013 01:47 AM   [ Ignore ]   [ # 7 ]
Member
Avatar
Rank
Joined  2011-02-14
Useful! Thanks!
Profile
Posted: 20 January 2013 06:22 AM   [ Ignore ]   [ # 8 ]
Member
Avatar
Rank
Joined  2009-04-30
Thank you DragonStorm for the expalination. Now i understand what it oes.
Profile
