Digital Art Zone
Point at needs an adjustment. Where is it.
Posted: 15 January 2013 07:42 PM   [ Ignore ]
Member
Rank
Joined  2012-10-04
I would like to have a head point at an object but the wrong axis is activated.
How do I change it?
Profile
Posted: 15 January 2013 11:07 PM   [ Ignore ]   [ # 1 ]
Power Member
Avatar
RankRankRank
Joined  2004-10-25
I’m not exactly sure I know what you mean by “the wrong axis is activated”, but here goes.
If you want tp turn a character’s head, you would go into the Parameters tab and use the “yrot” parameter of the character’s head to turn it.  You may also have to use the “yrot” parameter of the character’s neck as well.  It depends on how much of a turn you want the head to make.
I have also found that, depending on the pose, I have to adjust the “tilt” of the head by adjusting the Bend rotation parameter for it to look correct, because just changing the “yrot” parameter puts the head at a strange angle.
Hope that helps.
 Signature
OK . . . Where’s my chocolate?     Post Count —> 3,263 and growing!     Visit my Renderosity Gallery
It’s what you learn after you know it all that counts ~ John Wooden
Profile
Posted: 16 January 2013 06:13 AM   [ Ignore ]   [ # 2 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Point at aligns the twist axis, which is the y axis for the head, towards the target - as you’ve found that isn’t helpful. Changing the twist axis would not be simple (or rather, restoring the rigging afterwards would not be simple).
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 16 January 2013 06:37 AM   [ Ignore ]   [ # 3 ]
Power Member
Avatar
RankRankRank
Joined  2009-02-24
Edit: Misread.
Truth be told, I’ve never found an easy way to ensure a head points in the right direction. If I ever find some good scripting tutorials, it’ll probably be one of the first things I work on adding.
 Signature
Here be dragons
Profile
Posted: 16 January 2013 11:03 AM   [ Ignore ]   [ # 4 ]
Member
Rank
Joined  2008-06-12
Maybe just create a ‘Point-of-View’ camera parented to (and located in) the head, look through the camera, and rotate/tilt/pitch the head until it is facing whatever you want it to be facing?
Profile
Posted: 16 January 2013 05:37 PM   [ Ignore ]   [ # 5 ]
Member
Rank
Joined  2012-10-04
Many thanks guys
Profile
Posted: 16 January 2013 05:39 PM   [ Ignore ]   [ # 6 ]
Active Member
Avatar
RankRank
Joined  2006-08-19
I find point at to be most useful with spot lights and cameras, I create a small sphere that doesn’t show up in the render (its under settings) and use that as the Point At target
 Signature
http://rarethdigitalmusings.blogspot.com/
http://rareth1966.deviantart.com/gallery/
Profile
Posted: 18 January 2013 12:24 AM   [ Ignore ]   [ # 7 ]
Power Member
Avatar
RankRankRank
Joined  2004-10-25
Rareth - 16 January 2013 05:39 PM
I usually use a Null for the same purpose when trying to target lights at a specific point.
 Signature
Profile
