Digital Art Zone
import an obj file AND use a texture on it
Posted: 12 January 2013 10:16 PM   [ Ignore ]
Member
Rank
Joined  2007-08-19
I’m wanting the most basic of basic things here and Carrara is fighting me for it. I created a space ship in blender and exported it as an obj. However when I import the model into Carrara, Carrara does not allow me to put textures on it. Rather it allows me to put them on the model, they just never show up. In fact NO pattern will show up on my ship. What is going on?
Profile
Posted: 12 January 2013 10:43 PM   [ Ignore ]   [ # 1 ]
Member
Rank
Joined  2006-02-03
Torkuda - 12 January 2013 10:16 PM
Could be a few things.
1.  Normals are reversed
2.  Blender didn’t export texture coordinates
3.  No UV map (happens if you make a modification even if UV’d)
Profile
Posted: 12 January 2013 11:49 PM   [ Ignore ]   [ # 2 ]
Member
Rank
Joined  2007-08-19
Apparently blender needs to UV map first. Got it.
Profile
Posted: 13 January 2013 12:01 AM   [ Ignore ]   [ # 3 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
Design Acrobat - 12 January 2013 10:43 PM
Blender has the ability to do ‘dynamic’ UV maps (updates them as you go along, but it’s a check box and not enabled by default…).  Also, the textures/UV and such are check boxes on the OBJ export options.
In Edit mode, in Blender, hit the ‘A’ key twice…everything should turn orange…then Mesh > Normals >Recalculate Outside…then export.  Also make sure you’ve actually assigned a material.  You don’t have to assign a texture, in Blender…just a material.
 Signature
1432 old posts
My ShareCG gallery.
Just because something costs a lot, doesn’t mean it’s the best…
It just means it’s expensive.
Profile
Posted: 13 January 2013 06:07 AM   [ Ignore ]   [ # 4 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
mjc1016 - 13 January 2013 12:01 AM
That has got to be one of my favs with using Blender
 Signature
Pete
Community Volunteer:
If by some miracle I express an opinion then it is my own and not that of Digital Art Zone.
Somethings to Consider when starting to learn CG
My Render Thread
Proud member of the Bald Wizards Club
Profile
