Digital Art Zone
Would a Bikini requiring Victoria 4.2 Morphs++ work any well on V5?
Posted: 10 January 2013 06:08 PM   [ Ignore ]
New Member
Joined  2012-02-22
So I bought Victoria 5 shortly after I started getting into doing things with Daz 4.5 and as I go through the store now, I notice that all of the different character textures or elite textures for Victoria 5 are all posed in some sort of classy looking bikini. I’m looking to get a decent bikini that works well for V5.
After doing a brief search of the store, I found “Basicwear for V4 Unimesh” which I think would look decent on Victoria 5. The only problem, at least I think it might be a problem, is that it requires V4 and V4 Morphs ++ and does not say it is compatible with Victoria 5.
If I were to buy Basicwear for V4 Unimesh without owning V4 or V4 Morphs ++, could I use it with V5? Or would I just have to get the Genesis Bikini?
Help is definitely appreciated.
Profile
Posted: 10 January 2013 06:11 PM   [ Ignore ]   [ # 1 ]
Active Member
Avatar
RankRank
Joined  2007-12-07
I suspect that with auto-fit the bikini should work just fine with Genesis/V5.
 Signature
Some writings by a friend:
http://www.lizardsofthehost.co.uk/11.html
http://www.lizardsofthehost.co.uk/13.html
http://www.lizardsofthehost.co.uk/7.html
Profile
Posted: 10 January 2013 06:18 PM   [ Ignore ]   [ # 2 ]
New Member
Joined  2012-02-22
Okay then. Thanks. You guys here on the forums are pretty helpful.
Profile
Posted: 10 January 2013 06:41 PM   [ Ignore ]   [ # 3 ]
Active Member
RankRank
Joined  2012-02-04
The V4 morphs have no relevance on how well a clothing item will convert for use on Genesis, since the transfer utility ignores them anyway when converting the item from parametric to weight-mapped.  (It will still copy morphs over for you, but that’s more for using special morphs like “open/reveal/etc” than because you’d want to tweak the V4 Morphs++ morphs in the clothing.
 Signature
My deviantART Homepage
Profile
Posted: 10 January 2013 10:00 PM   [ Ignore ]   [ # 4 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
Although, if the morphs in the bikini do transfer, they would probably still do ‘something’...it’s just that they won’t be doing it to fit an Genesis/V5 ‘base’ shape.  It would be interesting to see what they would do.
 Signature
1432 old posts
My ShareCG gallery.
Just because something costs a lot, doesn’t mean it’s the best…
It just means it’s expensive.
Profile
Posted: 10 January 2013 10:07 PM   [ Ignore ]   [ # 5 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
You need the basic version, not the unimesh one (the unimesh is an add-on that requires the regular Basic Wear).
 Signature
FastGrab Alert Thread
Non-Genesis Items with Metadata
Plugin Version Numbers for DS 4.5
Updated Genesis Products
Products In Zips
Proud member of the Bald Wizards Club
Profile
