Digital Art Zone
3 of 8
3
Tutorial Uber Area Lighting: The Basics
Posted: 08 January 2013 01:55 AM   [ Ignore ]   [ # 31 ]
Member
Rank
Joined  2012-09-24
It is helpful sometimes to render the image with each one of your lights one at a time so you can understand better what each of the lights is doing. The first image show the scene lit by only the key, fill and accent lights individually.
The key light provides good lighting, but very deep shadows. This makes for an artistic kind of lighting that can sometimes be used for edgy portraits.
Just the fill light produces very flat lighting, which on it own is not very attractive. This is similar to the type of unflattering lighting you get with on camera flash. The shadows you get from the off axis key light make the image look more 3 dimensional and pleasing, but just the key light produces shadows that are too deep for most people’s preference. Combining the key and fill gives nice 3 dimensional lighting
Just the accent light is only illuminating the back edges of the arms and face.
The second image shows the combination of the key and fill, and the combination of all three lights. This shows the subtle change the back light makes in the image.
Image Attachments
Profile
Posted: 08 January 2013 02:01 AM   [ Ignore ]   [ # 32 ]
Power Member
RankRankRank
Joined  2007-06-22
What do you set your samples levels at on the area lights?
Profile
Posted: 08 January 2013 02:27 AM   [ Ignore ]   [ # 33 ]
Member
Rank
Joined  2012-09-24
scorpio64dragon - 08 January 2013 02:01 AM
The settings of all the parameters are shown in this post http://www.daz3d.com/forums/viewthread/14536/P15/#214381
I usually use 32 as a good compromise between render speed and quality.
Profile
Posted: 08 January 2013 03:12 AM   [ Ignore ]   [ # 34 ]
New Member
Joined  2008-11-03
Thanks a lot Mr.Mark
gupta
Profile
Posted: 08 January 2013 03:15 AM   [ Ignore ]   [ # 35 ]
Power Member
RankRankRank
Joined  2007-06-22
mark - 08 January 2013 02:27 AM
Ahh I usually have mine set around 24-28 but my render settings are higher, I find it helps get rid of that grimy look things, especially skin, can get sometimes.
Profile
Posted: 08 January 2013 03:35 AM   [ Ignore ]   [ # 36 ]
Member
Rank
Joined  2012-09-24
scorpio64dragon - 08 January 2013 03:15 AM
By render settings higher, do you mean the shading rate? What value do you use?
Profile
Posted: 08 January 2013 03:58 AM   [ Ignore ]   [ # 37 ]
Power Member
Avatar
RankRankRank
Joined  2008-03-30
Cheers everyone, esp Pete and Mark for all the helpful screenshots of settings etc, and for very clear easy to understand instructions (good for old farts like me!)
 Signature
[Join the little green box collection party!]
Ianz Place
Daz 3D Documentation
Daz 3D on YouTube
Daz 3D Forum Archive
Profile
Posted: 08 January 2013 05:50 AM   [ Ignore ]   [ # 38 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
Nice one Mark for helping out…much appreciated.
Ian nothing wrong with us old farts.
 Signature
Pete
Community Volunteer:
If by some miracle I express an opinion then it is my own and not that of Digital Art Zone.
Somethings to Consider when starting to learn CG
My Render Thread
Proud member of the Bald Wizards Club
Profile
Posted: 08 January 2013 06:50 AM   [ Ignore ]   [ # 39 ]
Power Member
RankRankRank
Joined  2007-06-22
mark - 08 January 2013 03:35 AM
Yes I have my render settings Shading rate set at 0.1 or 0.08
Profile
Posted: 09 January 2013 02:28 PM   [ Ignore ]   [ # 40 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
Yes like scorpio64dragon I often drop the main Shading rate first but it really does depend on the surfaces in the scene…example using UberSurface/HSS, Uber Surface 2 I have found that the Area Light Sample rate needs inceasing to 64 or 128.
 Signature
Pete
My Render Thread
Profile
Posted: 13 January 2013 03:17 PM   [ Ignore ]   [ # 41 ]
Power Member
Avatar
RankRankRank
Joined  2004-04-14
I did not read through the thread to see if this was stated yet, but in DAZ Studio it will always render the normals forward so it looks right in the scene.  However, if you are using a surface as a mesh light and the actual normals are flipped, it will not work right for you.
wancow - 04 January 2013 01:10 PM
Okay, so I’m playing with this using this model:
http://www.foundation3d.com/index.php?categoryid=38&p13_sectionid=307&p13_fileid=1677
I applied UberAreaLight Base to the 7-Lightsheets material zone (which are supposed to emit light).
In a previous render I used point lights to simulate the lighting, but I wanted to play with these light types.  The UberArea lights on that material zone is the only scene lighting present.
Okay, one thing I had an issue with is that I had to jack the Shadow Samples way up to 64 in order to get the graininess out of the shadows (on the lights in the material zone).  I have my render shadow samples at 16, but I’m still seeing graininess.  It took a whle to render, so I just wanted to ask, do I need to jack up the shadow samples in the render engine or do I need to up them in the lights themselves again?
I will double check that to see if the normals are flipped.
 Signature
My DAZ3D Store
My Free Stuff
My Art @ DeviantART
Ships of the Line - MEGA THREAD
How to use the Poser Format Exporter - **Updated 2013-02-09**
Profile
Posted: 13 January 2013 03:23 PM   [ Ignore ]   [ # 42 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
thx Matty yes I did included info about the normals (first page first post second paragraph)
Szark - 04 January 2013 08:00 AM
When a surface is used for a light source the direction of the mesh’s normal dictates the direction of the light projected. Take a standard Daz Studio sphere; its normals are facing outward…when used as a light source the light emits outward. This can be reversed by scaling the sphere negatively effectively turning the sphere inside out. Scaling the sphere up and using a sky and ground map as a light colour map makes for a great soft environment light.
 Signature
Pete
My Render Thread
Profile
Posted: 13 January 2013 05:12 PM   [ Ignore ]   [ # 43 ]
Power Member
Avatar
RankRankRank
Joined  2004-04-14
Mattymanx - 13 January 2013 03:17 PM
The normals are fine.  I am rendering the drydock with a starship in Lux as a test and its just fine.
 Signature
My DAZ3D Store
My Free Stuff
My Art @ DeviantART
Profile
Posted: 18 January 2013 12:43 PM   [ Ignore ]   [ # 44 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
I have just amended the first post of this thread to include a link to show how to use Area Lighting Base on an inverted Sphere as an Environment light http://vidaru.com/creating-simple-image-based-lighting-in-daz-studio-4/77154604
Makes for a nice soft overalll ambient light with occlussion but yeah a bit slower at render times compared with other sorts of lighting but it is a trade off with what results you want. Personally I would use this method more in the future.
 Signature
Pete
My Render Thread
Profile
Posted: 18 January 2013 12:44 PM   [ Ignore ]   [ # 45 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
Mattymanx - 13 January 2013 05:12 PM
Thx Mattymanx for confriming that and talking the time to check. smile
 Signature
Pete
My Render Thread
Profile
3 of 8
3
