Digital Art Zone
1 of 2
1
Weight map, one fits all is bad
Posted: 03 January 2013 05:47 PM   [ Ignore ]
Member
Rank
Joined  2009-11-20
Every Daz character I have, seems to use the default genesis weight map.
What is the point of weight mapping when even the vendor doesn’t tackle it.
Editing a weight map is a very confusing vocation.  Joint parameter name, would be better than X,Y,Z used in weight map tool.
Profile
Posted: 03 January 2013 05:49 PM   [ Ignore ]   [ # 1 ]
Power Member
Avatar
RankRankRank
Joined  2010-12-18
what problems are you having? what daz characters are you using?
Profile
Posted: 03 January 2013 06:15 PM   [ Ignore ]   [ # 2 ]
Member
Rank
Joined  2009-11-20
Using V5,M5,T5.  Weight map appears to be the same, particularly massive laterals when arms are raised above the head.
Profile
Posted: 03 January 2013 06:17 PM   [ Ignore ]   [ # 3 ]
Power Member
Avatar
RankRankRank
Joined  2010-12-18
what problems are you having? I’ve got everything but T5 (s5 maybe?) and I haven’t had any serious issues with the rigging. The shoulders a a bit strange in some poses but that’s how genesis is too so oh well. when do you issues appear and what are they? Do you have screen shots?
not trying to be a pain, just curious.
Profile
Posted: 03 January 2013 06:42 PM   [ Ignore ]   [ # 4 ]
Member
Rank
Joined  2009-11-20
Profile
Posted: 03 January 2013 06:55 PM   [ Ignore ]   [ # 5 ]
Active Member
Avatar
RankRank
Joined  2008-11-10
You don’t edit Genesis’ weightmap. You aren’t able to save the changes. You can create JCMs and adjust rigging for it.
Profile
Posted: 03 January 2013 07:01 PM   [ Ignore ]   [ # 6 ]
Member
Rank
Joined  2009-11-20
If thats the case, what is the point of the weight map tool.
Profile
Posted: 03 January 2013 07:08 PM   [ Ignore ]   [ # 7 ]
Power Member
Avatar
RankRankRank
Joined  2003-10-09
Rayman29 - 03 January 2013 07:01 PM
To make maps for original figures
 Signature
The Mighty Morphing PA Ranger
http://www.daz3d.com/shop/rawart/
Profile
Posted: 03 January 2013 07:23 PM   [ Ignore ]   [ # 8 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
RawArt - 03 January 2013 07:08 PM
And things like clothing…
It is part of the Content Creation tools.
 Signature
1432 old posts
My ShareCG gallery.
Just because something costs a lot, doesn’t mean it’s the best…
It just means it’s expensive.
Profile
Posted: 03 January 2013 07:24 PM   [ Ignore ]   [ # 9 ]
Member
Rank
Joined  2009-11-20
Agreed,  We can save changes to weight maps.
My original question remains.  Do all Daz genesis morphs use the same weight map?
Profile
Posted: 03 January 2013 07:54 PM   [ Ignore ]   [ # 10 ]
Power Member
Avatar
RankRankRank
Joined  2010-12-18
as i understand M5 came with his own rigging, my guess is Stephanie does too. I know mavka has a ton of JCM’s that Smay put into her. So vendors are tweaking the rigging as needed.
Profile
Posted: 03 January 2013 07:56 PM   [ Ignore ]   [ # 11 ]
Member
Rank
Joined  2009-11-20
I think few have used the weight map tool.  Its too confusing with its x,y,z instead of the joint parameter names, bend,twist…..etc.  It needs to be changed.
Profile
Posted: 03 January 2013 08:02 PM   [ Ignore ]   [ # 12 ]
Active Member
Avatar
RankRank
Joined  2008-11-10
Rayman29 - 03 January 2013 07:24 PM
Like I said before. You cannot make changes to Genesis’ weightmap. All characters are based on genesis, thus use the same weightmap. If you don’t like the way something bends, you make a JCM or adjust rigging.
Not sure how I can be clearer.
Profile
Posted: 03 January 2013 08:16 PM   [ Ignore ]   [ # 13 ]
Member
Rank
Joined  2009-11-20
Well you can save changes.  Just edit the map and save as scene or character.  I’m sure we could also save as an asset, although I haven’t tried.
Profile
Posted: 03 January 2013 08:17 PM   [ Ignore ]   [ # 14 ]
Active Member
Avatar
RankRank
Joined  2008-11-10
Rayman29 - 03 January 2013 08:16 PM
That’s not how it’s done, and you can’t. If you could, you risk messing up all of the movements in your morphs in genesis.
So don’t do it.
Edit: See, this is why I don’t answer too many questions. Someone asks, you give them the answer, then they want to spend a half hour arguing with you. If you knew the answer, why did you start this thread?
Profile
Posted: 03 January 2013 10:39 PM   [ Ignore ]   [ # 15 ]
Member
Rank
Joined  2009-11-20
Sorry, didn’t intend to cross.
But as I have said, JCMs aside.  Do all original Daz Genesis morphs use the same weight map?
Edit:- More to the point, if they do why?  Its similar to selling a custom texture map with a generic displacement/bump map.
Profile
1 of 2
1
