Digital Art Zone
12 of 13
12
Carrara Portrait Lighting
Posted: 17 September 2012 04:39 PM   [ Ignore ]   [ # 166 ]
Member
Rank
Joined  2005-05-21
head wax - 17 September 2012 02:25 PM
Thank you David!
Yes, I tried that with this one and it wouldn’t work for some reason (I exclude evrything bar right eye etc but the light lit nothing).
It might be that it is Ben?
I’ll check it out with K4.
thanks again smile
Some figures have multiple eye parts—be sure the light’s enabled for all the eye parts, and not just something hidden behind something else. (Can’t remember the parts—I bring this up because I had that problem, I was lighting the eyeball, but the eyeball was hidden behind the sclera or something, and it took an “ah ha” moment…)
Profile
Posted: 17 September 2012 05:00 PM   [ Ignore ]   [ # 167 ]
Active Member
Avatar
RankRank
Joined  2008-01-28
Thanks Carlton, yes I think that was the problem, good call,
I’m always going into the shader room and making things red so I can figure which is what part of the eyeball
ironic really…. smile
 Signature
http://andrewfinnie.blogspot.com.au/
Profile
Posted: 17 September 2012 05:39 PM   [ Ignore ]   [ # 168 ]
Power Member
Avatar
RankRankRank
Joined  2006-08-27
I’ve tried lighting just the eyes and failed as well. I suspected it was because the eyes that you see listed in the figure hierarchy aren’t the mesh, but the rig. I will have to experiment some more.
Profile
Posted: 18 September 2012 01:48 AM   [ Ignore ]   [ # 169 ]
Active Member
Avatar
RankRank
Joined  2008-01-28
you mean I been trying to light up bones? smile  smile
 Signature
Profile
Posted: 18 September 2012 02:40 AM   [ Ignore ]   [ # 170 ]
Active Member
Avatar
RankRank
Joined  2008-01-01
Well, that explains why i also can’t get it right. Lol
Profile
Posted: 18 September 2012 04:26 AM   [ Ignore ]   [ # 171 ]
Active Member
Avatar
RankRank
Joined  2008-01-28
smile
Girl with measles smile
one light near her right eye (on our left) using a circular gradient in the gel (The other light I had as rim is turned off)
Used EP’s glow globe at back - lots of possibilities thanks Evil.
The gradient is good because you can get (eg) warm at the centre, cool at the periphery and also control luminosity as well, so you could (eg) reverse it to make it lighter at the periphery
I think the light around her iris at the limbus is the iris texture - but (warning ocular talk ahead)  it looks like sclerotic scatterr in a way (light shone in the temporal region of your cornea bounces internally and lights up the nasal part of your conjunctiva-  - but could also be arcus senilus if she was another sixty years older)
tanks for looking smile
edit: I just noticed she has ‘poser nose’ left nostril (our right) ah well smile
Image Attachments
 Signature
Profile
Posted: 18 September 2012 08:57 AM   [ Ignore ]   [ # 172 ]
Member
Rank
Joined  2006-08-21
head wax - 18 September 2012 04:26 AM
smile
Well, she does have measles after all.
 Signature
CG and Me
Profile
Posted: 18 September 2012 10:09 PM   [ Ignore ]   [ # 173 ]
Active Member
Avatar
RankRank
Joined  2008-01-28
Heh, smile sorry I missed that.! Well it could be a case of Nasal septal perforation ! err I just read what causes it too :(
 Signature
Profile
Posted: 19 September 2012 09:00 AM   [ Ignore ]   [ # 174 ]
Member
Rank
Joined  2006-08-21
head wax - 18 September 2012 10:09 PM
No details necessary.
 Signature
CG and Me
Profile
Posted: 19 September 2012 02:33 PM   [ Ignore ]   [ # 175 ]
Power Member
Avatar
RankRankRank
Joined  2006-08-27
regarding restricting lighting to the eyes, (or other parts of the mesh for that matter) I did run some tests, and I could not get it to work for me. As soon as I restricted light to the model, then the model was illuminated. I’m even more convinced that I can’t light up just the eyes because the eyes listed in hierarchy are part of the rig. To bad there’s no way to include/exclude by other means, such as by shading domains.
Profile
Posted: 19 September 2012 02:50 PM   [ Ignore ]   [ # 176 ]
Addict
Avatar
RankRankRankRank
Joined  2009-07-13
dumbass Wendy idea
select the eye bits in vertex room
copy
new vertex model
paste
parent to eyes or select hip, attach skeleton, weightpaint to original eyes which have visibility turned off
I am not on computer so not trying it, just an idea!
or
export obj with morphs etc checked, import and delete all the non-eye bits before doing above
(if you want it posable, animated)
otherwise just use reimported obj’s and be done with it!!
 Signature
WARNING do not click tongue rolleye what will be seen if you do cannot be unseen.
Profile
Posted: 19 September 2012 07:38 PM   [ Ignore ]   [ # 177 ]
Active Member
Avatar
RankRank
Joined  2008-01-28
evilproducer - 19 September 2012 02:33 PM
thanks for that data evil, could be a goer for the “how I would like carrara to be improved thread”
 Signature
Profile
Posted: 19 September 2012 07:42 PM   [ Ignore ]   [ # 178 ]
Active Member
Avatar
RankRank
Joined  2008-01-28
wendy♥catz - 19 September 2012 02:50 PM
dumbass Wendy idea
copy
new vertex model
paste
or
hey wendy not so dumb arse, just lateral…
sound s like work tho,
smile
Whenever I copy some polys and paste them into a new object when I go back to the assemlby room they are the size of small planets on a hot day (1/1 scale proportiion )- so I must be doing sometghing wrong
 Signature
Profile
Posted: 29 September 2012 02:40 PM   [ Ignore ]   [ # 179 ]
Active Member
RankRank
Joined  2012-04-01
I have been trying to do a Poser Pro like portrait render, using a free Carrara light set, built-in V4 shaders and my very limited skills.
Here are the results, feel like I am halfway there, but no idea how to improve.
Free lightset from: http://www.sharecg.com/v/28074/gallery/7/Material-and-Shader/V4-Skin-Shader-kit-and-Lights-for-Carrara-6
Image Attachments
 Signature
Everything about Carrara: http://www.carraracafe.com/
Profile
Posted: 29 September 2012 02:52 PM   [ Ignore ]   [ # 180 ]
Active Member
RankRank
Joined  2012-04-01
Here is another comparison:
Image Attachments
 Signature
Profile
12 of 13
12
