Try turning off the CMS (in start menu) and then un-hiding files so that you can see ProgramData under your C drive. Go into that folder and under DAZ3D you will find a folder for the CMS. Go into that folder and delete the database files. Turn on the CMS again through the Startup menu and when you go into Daz it will have been reset. Unfortunately you will lose any folder setup you had but it should help to restart it. I have to do this at least every 1-2 months as it appears not like updates to my system.
Hope this helps someone to get it working.
How do you go in and “unhide” the files… and where do you go in after that to delete the database files? Need specifics please?
Computer education time…..You need to go to the Windows Folder Options…easiest way to get there is open Windows Explorer > Tools > Folder Options (see image below)
Okay… wow, According to cridgit this is where I should see the files:
C:\Program Files\DAZ 3D\Content Management Services\databases
Now, that might be a hidden folder, but I can’t figure out where the tools are to see hidden files and folders in Windows Explorer…
I’m using Windows 7, and there is no tools pulldown :(
It’s right above in the row of menus across the top of that area.
However, I’ve done that… I can’t find the databases - and I’ve gone to the other link above, but as I’m looking at it, I’m not certain where to delete the databases since I can’t find it.
Okay… found it in the My Documents section and so far, what’s going into the Recycle Bin is over 9.6 GB… yeah, REAL scary!!!
