Digital Art Zone
Downloading files from renderosity
Posted: 28 December 2012 04:18 AM   [ Ignore ]
Member
Rank
Joined  2012-11-29
Dumb question, but I’ve been trying to download zip files from Renderosity, and they keep disappearing into someplace called Appdate.  Can anyone tell me where I should be downloading them so they show up in DAZlibrary?
FYI, this wouldn’t be a problem if you guys made a boxing glove set, hint hint!
Profile
Posted: 28 December 2012 04:31 AM   [ Ignore ]   [ # 1 ]
Power Member
Avatar
RankRankRank
Joined  2012-04-07
colinmac2 - 28 December 2012 04:18 AM
You need to change the destination for downloads in your browser - possibly to a folder on your desktop, or the one called Downloads in your user account.
Then unzip them and manually place the files where they’d need to go.
To find what you have already downloaded, you have to “show hidden folders” and go to your user account and check the AppData folder.
I’ve seen boxing gloves for sale here but ? where atm.
Profile
Posted: 28 December 2012 04:32 AM   [ Ignore ]   [ # 2 ]
Active Member
Avatar
RankRank
Joined  2010-10-10
Have you told it to “Save” the file or is the download set to “Open”?
 Signature
Wendy
My freestuff: http://www.sharecg.com/pf/full_uploads.php?pf_user_name=Wilmap
My Deviant Art Gallery:  http://wilmap2.deviantart.com/
Profile
Posted: 28 December 2012 09:36 AM   [ Ignore ]   [ # 3 ]
Power Member
Avatar
RankRankRank
Joined  2004-10-25
Someone ask for boxing gloves?  Check them out here —> http://www.daz3d.com/shop/fm-fight-club-clothing
Granted they’re practice gloves rather than kind you would wear in an actual fight in the ring.
 Signature
OK . . . Where’s my chocolate?     Post Count —> 3,263 and growing!     Visit my Renderosity Gallery
It’s what you learn after you know it all that counts ~ John Wooden
Profile
Posted: 28 December 2012 12:14 PM   [ Ignore ]   [ # 4 ]
Member
Rank
Joined  2012-11-29
“unzip them and manually place the files where they’d need to go.”
Yes, but I’m unsure exactly where they need to go.  I’m looking for a tree, I think.
And I’ve seen those “practice gloves”, and they’re not what I’m looking for.  I’m looking for the actual ring gloves.
Profile
Posted: 28 December 2012 12:56 PM   [ Ignore ]   [ # 5 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
If the top-level folder is named “Runtime”, merge it with the Runtime folder in “My Library”.
If the top-level folder is named “Content”, merge what’s UNDERNEATH “Content” with the folders underneath “My Library”.
 Signature
FastGrab Alert Thread
Non-Genesis Items with Metadata
Plugin Version Numbers for DS 4.5
Updated Genesis Products
Products In Zips
Proud member of the Bald Wizards Club
Profile
Posted: 28 December 2012 01:42 PM   [ Ignore ]   [ # 6 ]
Member
Rank
Joined  2012-11-29
Am I supposed to put it in ‘Documents’?  I’ve been trying to unzip the whole document into DAZ 3D,\documents\runtime\runtime and there I run into a brick wall.  I’ve also tried document\studio\runtime\my library\  and there I run into another wall.  Can someone PLEASE just give me a sample tree to download it into?
Profile
Posted: 28 December 2012 03:39 PM   [ Ignore ]   [ # 7 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
Do not Download the Zip file to any of those locations. Download to a temp folder, then use a UNZIP (Win 7 has one built in) to UnZip the downloaded zip file. After the File is UnZipped open the Folder it creates and then you Drop the RUNTIME folder (if its a poser only type file) into your My Library Folder, it Should then give an option to MERGE the two Runtimes into one larger Runtime. Tell it OKay or Yes.
 Signature
My art on DeviantArt and my Project The Primitives a year in the life.
Father of the Stupid threads, find the Stupid you need here.
I may not be worth much but most people tell me my two cents were well spent
Profile
Posted: 28 December 2012 04:34 PM   [ Ignore ]   [ # 8 ]
Member
Rank
Joined  2012-11-29
I’ve done all that, and it’s not showing up.  When I search the system, it says it’s there in My Library, but when I start up DAZ, it’s nowhere to be seen.  And the Search function in DAZ doesn’t show it at all.  Everything says it should be working, but DAZ can’t find it.  If it wasn’t for a friend of mine using it, I’d say Renderosity was incompatible w/ DAZ, but he swears it works.
Profile
Posted: 28 December 2012 04:38 PM   [ Ignore ]   [ # 9 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
Open the Content Library Tab, then look in your POSER Formats section. Older files will not show in Smart Content.
 Signature
Profile
Posted: 28 December 2012 04:45 PM   [ Ignore ]   [ # 10 ]
Member
Rank
Joined  2012-11-29
It’s not in there either, or in Categories.
Profile
Posted: 28 December 2012 04:52 PM   [ Ignore ]   [ # 11 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
This should be the proper full path. Documents/DAZ3D/Studio/My Library/
The UnZip should place the files inside the existing Runtime for you.
 Signature
Profile
Posted: 28 December 2012 05:00 PM   [ Ignore ]   [ # 12 ]
Member
Rank
Joined  2012-11-29
YES, YES IT FINALLY WORKS THANK YOU SO MUCH!!
Profile
Posted: 28 December 2012 05:10 PM   [ Ignore ]   [ # 13 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
Your more than welcome, happy rendering.
 Signature
Profile
