Well I got an answer from when I opened my ticket:
As long as you aren’t referencing the topology of the figure then that would be fine. If your 2D render is just a render of the wire frame mesh then that would not be ok. If you did the latter you would be bound by the same terms and conditions of that the original Genesis figure has.
You can re-do the topology of the Genesis figure, and in fact I think you’ll find you won’t get very far if you don’t redo the topology of the figure. However you are still bound by the same terms with your ‘new’ genesis figure as you would be with the original.
I hope this answers your questions.
Hopefully that’ll also clear things up to those wonder the same thing as I was.
