thank your advice,, but ,,it is not question about how to make UV map, or modify UV map of obj,,^^;
I know how assign surface grouping in poligon group editor in ds or by hexagon shading domain.
or if I want to do,, I can do samethings in Blender,, and know how to make UV map,,,(not good but can do )
I understand,, change UV map and save as new obj. and make new figure , or save as prop in ds.
but about genesis, we can change toggle UV map default V4 to V5, or M4 S5 etc.
and we need not save two genesis figure. just change UV set in data folda I think.
so I want to do sametinghs about the figure or prop wihch I have made and saved .
make two or three different UV map (I can do it by obj)
and save each UV set to use same figure, and toggle them in surface tab like genesis.
if I need to make new figure about each obj with different uv maps?
but I have only one genesis.dsf in data, and I can toggle different UV sets.
or genesis loading different obj from data, and change UV when I toggle UV sets in surface tab?
OK,,OK,, I find the way ^^; I thought must need to save UV set first,, but it is wrong^^;
I thought if I need to change name of UV set, because there only exist “default” uv set,
though I saved UV of obj with modified UV, as another product name.
and I tried transfer utility ,overwrite obj by new uv, then save as UV sets,,
but it seems not work,,I get only default UV sets in different folda, and I can not toggle it.
but It seems more simple. I just need to “Load UV set,”, and it is simply obj file,,,
after that I can toggle bear eye UV ^^;
1. export the figure or prop as obj to 3D tool.
2. modify obj UV map, and save it where you want (as same as making morph target,,) I saved it as “newUVset.obj”
3 select the figure in ds, and go to surface tab option, “load UV set”
4 file exproler open, then simply select the “newUVset.obj” which I saved , click accept. and name it as new UV set.
5 now I can toggle the UV set,, default and TKteddy2 ^^;
I know many user already may have known it,,
or find by themselves but record here,, what I udnerstand ^^
(there is no clear guide about each option still ( T T#)
so, such simple thing is difficult for me. who have only known ds 4 , not poser, or ds 3)
Click thumbnail to see full-size image
