Garstor - 27 December 2012 04:50 AM
I am curious about Replica though - what does it permit that the Carrara Replicators do not? (i.e. why should I buy it?
They approach the same problem from different directions.
Carrara’s built in Replicator arranges sub-objects in a limited number of shapes (ball, arc, grid, etc), and has randomizing parameters so the instances can each look a little “randomized” within their position (height, rotation, slightly off position, etc). Whether you are using Replicator or Surface Replicator, it is sort of a top-down concept: the replicator defines an area (or volume, or surface) and fills it in with sub-objects….
Inagoni’s Replica is similar, but it has some extra parameters like blending with a shader to create variation in color (creates new shaders), and seems to always create new objects… The interface is a little baffling, I admit. For most cases the built-in Replicator is easier to use… Replica was a plugin before Carrara had the built-in Replicator…
But Replica Array is a modifier that creates instances and translates them from the original: rotation, offset, scale. In the case of my small truss arc, I am able to create the next instance (and the next and the next) by setting how much each iteration will rotate and offset from the one before…. So for example from one small section of fence I could create a long fence that repeats for miles or curves to enclose a corral…. Replica Array doesn’t have the randomizing parameters, but you can scale each object as a percentage of the one before (think: wedding cake tiers, getting smaller with each repetition)..., and you can ANIMATE the parameters (think: mechanical tentacle).
Another case where the modifier would be perfect is a camera iris that could open and close with mechanical “blades” (like the iris on the Stargate SG-1 ring) you’d create one “blade” and control the whole iris by animating the modifier…
There’s a couple of examples on the Inagoni Replica page, the linked chain, and the animated thing that show what the modifier (they call it a “deformer”) can do…
http://www.inagoni.com/e107_plugins/content/content.php?content.5
Click thumbnail to see full-size image
