Digital Art Zone
Replacing textures in the shader
Posted: 25 December 2012 08:27 PM   [ Ignore ]
Power Member
RankRankRank
Joined  2006-07-31
Hello.
I might remember it wrong, but in DS3 when you applied a texture MAT with Ctrl, you could have been prompted to check to replace or to ignore the textures, which allowed fast texture swap while keeping texture parameters like specular strength same. I think that in DS 4.5 this isn’t working with Poser-like MATs anymore, only with DS-matposes. Am I missing something or that feature is really gone?
 Signature
a way to transfer morphs to Genesis without Gen-X
Profile
Posted: 26 December 2012 12:20 AM   [ Ignore ]   [ # 1 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
I don’t recall DS3 being able to do that with Poser-format mats, it’s always been a feature that requires DS-format files.
 Signature
FastGrab Alert Thread
Non-Genesis Items with Metadata
Plugin Version Numbers for DS 4.5
Updated Genesis Products
Products In Zips
Proud member of the Bald Wizards Club
Profile
Posted: 26 December 2012 06:30 AM   [ Ignore ]   [ # 2 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
fixmypcmike - 26 December 2012 12:20 AM
I wondered about that a few weeks back…this explanis alot.
 Signature
Pete
Community Volunteer:
If by some miracle I express an opinion then it is my own and not that of Digital Art Zone.
Somethings to Consider when starting to learn CG
My Render Thread
Profile
Posted: 28 December 2012 04:47 AM   [ Ignore ]   [ # 3 ]
Active Member
Avatar
RankRank
Joined  2007-01-08
I haven’t checked with the latest format, but in the old dsa/dsb format, the code to replace the textures was in the dsa/dsb preset itself, therefore it doesn’t work, generally with Poser presets. However it does work if you have the dsa/dsb with same name and same location as the Poser preset (there’s an icon on top left corner of the Poser preset to indicate that a DS preset will be loaded instead). A solution would be to save a deprecated dsa/dsb preset whenever you find a Poser preset that doesn’t have the matching DS preset and make sure to place it in the same Poser runtime folder containing the material preset.
Profile
Posted: 28 December 2012 09:19 AM   [ Ignore ]   [ # 4 ]
Power Member
RankRankRank
Joined  2006-07-31
Thanks, ReDave, this is probably what I was doing to make it work. So strange, I was absolutely sure that pz2 alone could be used for replacement in shaders but I’ve checked in DS3 and no, they can’t.
 Signature
Profile
