Digital Art Zone
Collision in DS4.5
Posted: 24 December 2012 05:14 PM   [ Ignore ]
Active Member
Avatar
RankRank
Joined  2012-02-07
I’ve know of this but I’ve never known exactly where the option is.  I know that you’re limited to one collision per item and that Autofit is technically an example but I’ve never known anything past that.
 Signature
http://streetteam.bigcartel.com
Profile
Posted: 24 December 2012 09:03 PM   [ Ignore ]   [ # 1 ]
Active Member
RankRank
Joined  2012-02-12
Just off the top of my head, if the item already has a smoothing modifier put on it, then you’ll find it under paramaters—> general—> mesh smoothing.
If it doesn’t have a modifier already on it, then select it in the scene tab and then (i think go to edit—>figure—>smoothing modifier. That may not be right.  (or edit—>object—>smoothing modifier if you’re working with an object, not a figure.) That should be enough to get you in the right area of the menu, if it’s not quite right. (I’m away from my own computer right now.)
Profile
