Hi, sorry this is my first post and stuff but I got a problem and would like to ask for your help.
I mostly use Victoria 4.2 for renders, and often I have clothes that don´t fit her and have insufficient morphs to fit her. What I usually did with DS 4 Pro was scaling the clothes or only parts of it and mesh smoothing to properly fit it to the figure. This worked pretty well with DS 4 Pro.
Now a couple of days ago I installed DS 4.5.1.6 (Win 7, 64 bit) and all of a sudden I can not scale any clothes parts anymore, on clothes that are fir to V4.2. I usually select lothing parts like hips or abdomen and scale them with the parameters tab. It always worked fine with DS4 but in DS4.5 it does not. The scaling values are showed right in white color, like x > 82% but the item itself is not scaled, it keeps it´s original form and the scaling is not applied. This only happens when the clothing is “Fit to”. When the clothing is stand alone without being assigned to a figure the scaling works right. If I do that and then assign the clothing to the figure, it´s shape also resets to its original shape, but keeps the changed scale values in the parameter tab. This happens on V4 and V4.2 so that´s not the problem. It also happens when I load an old DS4 scene where everything worked fine, all the scaled clothing assigned to a figure resets to it´s original shape.
Sometimes I also use the translate function for some clothing parts, but this also stopped working. It shows the right values in the parameter tab but instead of translating the part it seems to get rotated or bend or such. I use scaling and translating quite often on clothes, and this problem really bugs me. I also tried to switch on/off the auto fit option in the preference tab of DS but it did not change anything.
Can someone please help me?
