Okie here are the fixes as promised
The usage instructions below are also included as a Read-Me file inside the ZIP…
http://www.ichloe.com/dollies/YoungTeens_TeethFix.zip
Justin and Julie Teeth Fix
These morphs correct the teeth size and placement on the Justin and Julie Young Teens figures. This is a temporary fix until a permanent fix can be implemented by DAZ on the base figure files.
USAGE:
UnZIP the two morph target files to your DAZ Studio 4.5 base “My Library” folder using the paths provided. Upon loading a new copy of Genesis, these morphs can be found in the following regions of the Genesis figure parameter settings:
Actor:Male:Real World:PHMJustin_TeethFix
Actor:Female:Real World:PHMJulie_TeethFix
(Note that this will be in the same location as the Justin and Julie full body morph dials)
Set the parameter value of these morphs to the same strength as you have the Justin and/or Julie morphs. These Teeth Fix morphs work on both the Full Body Justin and Julie morphs as well as the Head Only morphs.
Thorne <3
