It’s a different system, you have to create a new log-in for the bug report.
Thanks Ani! - I swear Daz likes us to have multiple accounts with them lol
You can use the same login info…it just needs to be set up again.
I’ve dealt with many places that use that system and yeah, all of them require a separate login to Mantis…it is a security feature, that actually does work. It keeps the bugtracker separate from everything else.
And it most definitely was/is caused by using the smoothing brush too close to the mouth, with the teeth unmasked.
I tried a couple of experiments, using Blender and it’s sculpting tools (don’t have Zbrush) and it didn’t take much to get them to look that way. Just a couple of ‘light taps’ on the lips (mainly where they meet). The first tap opens the lips just a fraction, almost not enough to see…the second hits the teeth directly.
As said on SCG: DS 4.5 YT 5: A temp fix, of sorts, for the YT5 teeth. Not meant as a solution, only as a stop-gap till better comes along.
Teeth Adjustment 2 and 3 (inc) are just fine tuners for the tooth shapes
Should work alright.
Note: Shown on Justin. The values for Julie are a little lower: Somewhere around 60% of Teeth Adjustment, and the shapers until you have what you want. Have fun
Heya mjc, I think we were both working on it at the same time here. Can we still get yours, also? Mine are more a band-aid, really, since we’re not sure when an official fix will come in. So the more unofficial fixes, the better.
You beat me to it…if I wasn’t having problems with my CMS database, I would have had it out last night…it really is a PITA that saving content for distribution is so difficult with a non-working CMS. (fortunately I don’t bother with Smart Content or categories…so wiping and going back to the default db wasn’t painful).
Oh well, sometimes you’re the windshield; sometimes you’re the bug.
Eww, I’ve been luck with the CMS lately, the past few versions have been good to me (knock on wood) but in the past that beast used to give me complete and total nightmares :(
