Incidentally, that’s basic Julie with the Teeth Smoother modifier set to 0.4. The following is Justin, who requires a bit of a stronger setting. This is at 0.65 on the Teeth Smoother.
Yeah, the one thing to remember about the smoother is that it’s designed to give more of an anime look to the mouth, , so it moves everything towards a single uniform size to create the classic anime “dental horse shoe"shape. It helps a lot in a case like Julie and Justin, but comes at the cost of a lot of the character you get with bigger front teeth, sharper incisors, etc.. Dental Plan is obviously a better solution overall, and everything else is just a stop gap.
Can you post a screenshot? There is a difference between smoothing teeth and closing gaps. I’m interested to see the results:)
I have such a screenshot myself…
...and another render using the teens.
That looks great, too. The options are multiplying:
Dental Plan (not available quite yet)
Hitomi teeth smoothing (I don’t have Hitomi, though)
Hiro 5 teeth smoothing (I don’t have Hiro 5 either)
SickleYield’s fantasy teeth (according to SY, via PM, it was not designed for teen teeth but sort of helps. Tests show that it makes the ends kind of rounded)
I wish they would have put a teeth smoothing morph in the teens, like in Hiro 5 and Hitomi.
Edit: fixed typo
To be frank, it’s a little disappointing we need to resort to any kind of workaround just to make the teeth look normal, much less purchase an entire new set of morphs for the task. Still, Hitomi’s teeth smoother will suit my humble needs for the moment.
I do secretly hope they’ll release an updated version which fixes this issue though.
The merchants that created this product should be making a fix and update, folks shouldn’t have to look for other solutions. From my own experiences in ZBrush using the smoothing brush without masking the inner mouth can cause this to happen as well as exporting the Genesis figure at High Rez… Genesis should always be exported at the lowest rez to any modeling app to avoid these sorts of issues with just about everything with detail. I found it also causes loss in ear detail and the nostrils to shrink and smooth out too much. Again, you should NOT have to be looking around for fixes. The merchants need to fix their product.
How do we encourage the vendor(s) to fix this? Is a Mantis bug report the way to go? Is there a better way?
Not sure what to suggest. Perhaps a ticket. Or track down Thorne here on the forums and send he/she a PM about it and direct the person to this thread making sure you include the thread count number where the complaints started.
Not sure what to suggest. Perhaps a ticket. Or track down Sarsa here on the forums and send he/she a PM about it and direct the person to this thread making sure you include the thread count number where the complaints started.
Right… found the thread and found that I was wrong about the merchant. Sorry about that. Corrected above with a link to the thread where the WIP’s were posted. PM away!
I just went back to look at product promo images. Neither Justin or Julie have any images with teeth showing in the promo images. However the Faces for Teens promo images show lots of teeth, and they look fine. I don’t have that product. I wonder if it has a teeth morph fix built into the poses, or is something just went badly wrong with the Justin and Julie models after the promo images were created. Or, I wonder if there is interference from some other package we have installed that affects the teeth in a way the vendor did not anticipate.
Can anyone test the faces of teens to see it those expressions fix the teeth?
