The LIE tiles overlays automatically with the diffuse map.One would need to be computer programmer to prevent this - which I’m not.
That being the case, you can always use the Hybrid Grunge Bundle shader overlays to grunge things up. It works, but it does tile with the textures so looks better at some times than at others. I’m including quick tiling presents all the way from 1 to 20. You’ll need to use these pretty much every time you use this product because it will tile differently on different models. The lower the tiling, the better the grunge shaders will overlay.
If Shader Mixer showed a proper tiled preveiw instead of a white one, it could be done there. But the “white til render” thing is a deal breaker and would quickly suck all the fun out of experimenting with multiple tiled presets.
Most of these will already be either worn or grungy, because I see that as the premium product.
