PhilW has his instructionals on availible through infinite skills (I use the app on my Ipad).
I would buy your instructionals!
I have PhilW’s tutorials too…they are fantastic. would love for Howie to put the info on how he creates his scenes into a tutorial. what he does in Carrara is amazing.
most of Howies work out the box actually but Daz installed the whole folder wrong
I am inclined to agree here. I have been getting caught-up on my runtime installs and Valle Alpina did not show-up in my Browser Scenes. I am giving the install another whirl now; I’ll have Process Monitor watching my folders to be sure there is disk activity where it should be.
Echo that thought! A tutorial like that would be an amazing bit of Carrara education. Although Howie rules the landscape scene market…does he really want to let the unwashed masses into his playing field?
LOL, ok, all my leaves etc loaded from default installer but these are wrong, what leaves SHOULD it be I wonder? more pine bristles like the others?
I am seeing even weirder issues Wendy.
For example, the saved camera “Position 1” ought to have rendered a vista not unlike the previews of the scene. Instead, I got “lost in the forest.” This seems to be happening with all the saved camera positions so far (working on render #3). I’ll try to capture some screenshots of this oddity later.
yes. has correct data sub-folder but is not in scenes, I had to manually add it,
my cameras ok though
still rendering my big 12000 x 6000 fish eye, might be 2 days by looks.
It must still be too early for my brain and the coffee hasn’t kicked in yet. I’m not following you on the way to correct this.
If the attachments worked; I should be showing the Assembly Room when set to saved Position 4 (a view of the creek, conifers trees on either side and the gorgeous mountain background). Then is the render from that view…
Edit: UGH! The attachments aren’t taking for some reason and I’m not thinking clearly enough to figure out why yet…
