I am using DS4.5, but this issue also occurred in DS4, and it’s one of the things that is a small issue, but one that drive’s me nuts.
Occasionally the pivot point of the camera gets screwed up. It behaves like you are pivoting around a remote point, moving the camera, rather than orbiting the camera in place without changing the camera’s location. The only way I’ve found to restore the camera is to click the ‘reset to default’ camera button in the viewport (the circle with the arrow pointing up). While that’s tolerable for the perspective cam, it’s a real nuisance for defined cameras, as you then have to move them back into place.
Anyone have any ideas what might cause this? And if so, how to prevent it? I don’t have a way to reproduce this reliably, so I’ve not created a bug tracker issue for it.
ctrl-shift-a (cmd-shift-a for Mac) will aim the camera at the selected node, ctrl-f (cmd-f for mac) wil point at and move to frame the selected item, which should fix the issue without having to do a full reset. Have you deleted an item you had framed or aimed at? I don’t know if that will; cause the loss of focal point, but it might.
Appreciate the feedback, though I don’t thin that’s the cause. My cameras are all manually positioned and aimed. I do not use aim at/point at on cameras. And when this happens, the pivot point usually seems to be somewhere odd, not part of any particular node in the scene list (even accounting for it being the center of the bounding box of the node). I also do not use the frame button, since my experience with that function is that it’s always been broken. (E.g., with Genesis selected, click the frame button and I get zoomed way out like I had switched to a distant light source.) The only camera tool I use (I don’t count pan/tilt/zoom as ‘tools’ even though they are located in the same area of the viewport window) is the one to reset the camera to its default location. This happens pretty regularly for me, and the only keyboard shortcuts I actively use are the tool selects (e.g., alt-shift-g for the PGE) and ctrl-shift-l to activate Reality.
No, my cameras are usually at the top level of the scene list. Only when I have several cameras in one scene will I sometime create a group for them. This also happens with the perspective camera (which is what I mostly use while working on a scene), which can’t be parented since it’s not part of the scene list.
I’ve been playing with this some more, and I don’t think I’ve described it correctly. When you orbit the camera, it does always move the camera around the pivot point, but it does it at a ‘sane’ distance based on close you are to the object. The problem I have is that when I’ve been zooming in and out a lot, it’s like the orbit distance gets stuck somewhere. Thus, if you’re zoomed in close on a figure (e.g., close to the hands while posing the fingers, or close in on a mat zone while working on surface settings and doing spot renders), you go to change the camera slightly and instead it flies you away from the figure as it thinks the pivot point is way out in the distance. Thus, using the hands example, instead of letting you check different angles of the hand, pivoting mostly around the hand, it starts pivoting as if it was focused several meters behind the hand and you orbit completely away from the figure. So when it gets confused, you have to orbit then pan then orbit then pan then orbit then pan just to keep the hand centered in the viewport.
I personally have not seen this happen. Are you sure that you have not accidentally clicked somewhere in the viewport instead of having the object you wish to orbit around selected? I do find that if I do center on selected item. When using this feature. It works every time.
My normal tool is the surface tool, which makes it pretty clear what you have clicked on since it highlights the surface in the viewport. So I don’t think this is a case of accidentally changing the selected item. Also, when posing, I don’t do it with dragging within the viewport. I have the parameters pane open and adjust the translate/rotation values there to get the most precision, so the mouse pointer usually isn’t even over the viewport except when I go to move the camera.
And while on the topic of the camera, is there a setting somewhere to adjust the ‘step size’ that rolling the mouse wheel zooms in/out for each tick of the wheel? When you are working zoomed in close, the zoom step is way too large and ends up taking you inside the object.
I’ve had this problem fairly recently and it was happening quite often for a period, and now it hasn’t happened for a week or two. Very strange. I was curing it by clicking the “camera frame/aim” button with the object I was working with selected. I tried various strategies and this was the only thing I tried that cleared it (obviously, the reset button does, but I hadn’t got as far as trying that). This was mostly with the perspective view camera, but I use this very much more than defined cameras, which, relatively speaking, I hardly touch. If it’s a named camera, does the problem come back if you undo after resetting?
I’ve had this problem fairly recently and it was happening quite often for a period ...snip… This was mostly with the perspective view camera, but I use this very much more than defined cameras, which, relatively speaking, I hardly touch. If it’s a named camera, does the problem come back if you undo after resetting?
Nice to hear I’m not alone with this.
I use the perspective camera 99% of the time, so it’s hard to say how it behaves with a named camera, since I spend much less time with them and don’t recall the specifics. My scenes almost always have just one named camera in them, which is the actual shot for the scene. (Some scenes I’ll do a couple camera angles, and then make additional cameras.) I don’t use cameras like some folks to while composing a scene, to have multiple views to switch quickly between.
Another pet peeve of mine with the camera: aspect ratio should be a property of the camera, not a global render property. When I do have multiple cameras for a single scene, it’s usually one that is landscape orientation while the other is portrait. I’ve taken to including the orientation in the camera name so I know what I have to set the render parameters to when I go to export the render to Reality.
I also would like to know an answer for that one.
Not as far as I know, it would be handy - or having it scroll in bigger steps or smaller steps with modifier keys.
Sounds like a candidate for the ‘feature request’ thread to me…
