Digital Art Zone
Preference question.
Posted: 16 December 2012 11:35 PM   [ Ignore ]
Active Member
Avatar
RankRank
Joined  2011-11-16
I have a question about the Preferences in Daz Studio 4.0 Pro. I’m working on a piece that needs to have ten characters in the scene, yet, I have a hard time getting even six or seven of them into the scene without crashing. The file size simply gets too big. I’ve tried the Export as object rout, but that really screws up the textures and even the scene after trying the second character. (including poke-through where there was none previously, and the Diffuse, Specular, and Ambient going out of wack).
Under Preferences> Interface, there is a slider titled OpenGL Textures that goes from (high)Performance to (high)Quality. My question is would lowering the quality to increase performance, allow me to get more characters into the scene? and will that affect the final render or just what I see on the screen while working on putting the scene together before rendering?
Profile
Posted: 17 December 2012 12:28 AM   [ Ignore ]   [ # 1 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
When is it crashing?
Is it during a render or still in preview?
What video card?  How much video memory?  How much system memory?  What OS?  What’s the bit count?
 Signature
1432 old posts
My ShareCG gallery.
Just because something costs a lot, doesn’t mean it’s the best…
It just means it’s expensive.
Profile
Posted: 17 December 2012 12:52 AM   [ Ignore ]   [ # 2 ]
Active Member
Avatar
RankRank
Joined  2011-11-16
I render to RIB now and do my renders in the stand alone 3Delight. Thus, the crashes I’m dealing with occur while I’m trying to add characters to the scene, particularly once I try to load seven or more characters, even as few as six characters in some cases (depending upon what else is in the scene).
I’m working on a 1.83 GHz Core Duo Mac Mini with 2 GB of RAM at 667 MHz bus speed, a GMA 950 graphics card with 64 MB VRAM of shared system memory.
For the record, the characters I load into my scenes are fully textured and clothed, saved as .daz files, not character presets.
Profile
Posted: 17 December 2012 01:18 AM   [ Ignore ]   [ # 3 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
You are so far beyond memory limits at this point, it’s not going to happen…
First you are starting out with just 2 GB of RAM…with DS, the OS and anything els (if anything else) taking a chunk of that…then you are using a graphics that has extremely low onboard RAM, so an used above that is going to eat system RAM…
Figure somewhere between 200 and 400 MB/fully clothed/texture character.
 Signature
1432 old posts
My ShareCG gallery.
Profile
Posted: 17 December 2012 01:31 AM   [ Ignore ]   [ # 4 ]
Active Member
Avatar
RankRank
Joined  2011-11-16
So, what about the OpenGL quality slider? will adjusting that have any effect at all?
Profile
Posted: 17 December 2012 02:00 AM   [ Ignore ]   [ # 5 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
Tramp Graphics - 17 December 2012 01:31 AM
Not really…it may squeak you out a few more MB, especially since you have shared video memory, but probably not enough to get a seventh character…(maybe not even a sixth), reliably.
 Signature
1432 old posts
My ShareCG gallery.
Profile
Posted: 17 December 2012 06:05 AM   [ Ignore ]   [ # 6 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Which figures are you using, and how are you loading them? If it’s one of the older, pre-Genesis figures, and you are loading from the Poser formats area then all of the morphs get loaded - if you save a base figure as a scene (or scene subset for DS4.5) then when you load that only active morphs will be brought in, which may get you a bit more headroom.
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 18 December 2012 12:18 PM   [ Ignore ]   [ # 7 ]
Active Member
Avatar
RankRank
Joined  2007-01-08
Downsize the textures to 1*1 pixel (and change their name), DS should probably be able to handle ten figures then. Export to RIB and then replace your textures in the collected folder with the original (or somewhat reduced if even 3Delight can’t handle everything).
Profile
Posted: 18 December 2012 01:01 PM   [ Ignore ]   [ # 8 ]
Addict
Avatar
RankRankRankRank
Joined  2011-12-10
Tramp Graphics - 17 December 2012 12:52 AM
When you get these issues resolved, would love to see a tutorial or an overview of how to deal with your rib files in 3Delight!  I have the freeware version and have a little trouble figuring it out…
 Signature
My DeviantArt Galleries
My ShareCG Gallery
OPENSUBDIV Testing and Discussion
3Delight Surface and Lighting Thread
Profile
Posted: 21 December 2012 05:55 PM   [ Ignore ]   [ # 9 ]
Active Member
Avatar
RankRank
Joined  2011-11-16
Richard Haseltine - 17 December 2012 06:05 AM
All I use are Genesis figures for my characters, but they all use the full set of morphs I have (except the males don’t use the morphs I converted through Gen X (being female genital morphs), or at least have full access to them, namely the base morphs, M4 V4 shapes fore Genesis, Ryuu International morphs, Die Tryings 182 Morphs for Genesis, RamWolf’s body morphs, Jabba’s Pin-up girl morphs, Adam 001’s proportion morphs, and Ooom Fooyat’s facial morphs.
As far as my project, I managed to get all ten in there by turning the four lone individuals into objects and only keeping paired characters that are in physical contact with one another as figures (namely Tommie and Kageto, Marc and Maria, and Baby Chris and Grandpa Mirandez). It’s still a huge file topping out as a 56.9 MB .DAZ file and the RIB file (which is currently rendering) is 756.4 MB.
Profile
