Digital Art Zone
Finding newly installed content in Default but not in Unassigned
Posted: 16 December 2012 04:51 PM   [ Ignore ]
Active Member
Avatar
RankRank
Joined  2003-10-09
When I install new content, sometimes it goes in Unassigned where I can find it, and sometimes it goes into other Default categories.
To make categorizing easier, I usually only install one product at a time, or a combination of obviously unrelated content.  Because the Unassigned category is always empty, everything in here can be immediately found, no problem.  However the non-Unassigned Default categories are a bit trickier.  Theoretically one can look for the blue highlighting to find the content.  Unfortunately sometimes the blue highlighting is not removed for empty categories which would gradually create more and more categories to have to look through to find your newly installed content, and of of course if you actually try to use any of the content (perhaps to see exactly how it interacts with existing content to determine where to put it) the blue highlighting will be lost.  Short of manually looking at every single category and subcategory in the entire system under Default, I don’t see a good way to find lost content in here if you don’t know it’s name.
How do other people avoid this problem?
Profile
Posted: 16 December 2012 05:01 PM   [ Ignore ]   [ # 1 ]
Addict
Avatar
RankRankRankRank
Joined  2011-12-10
That’s been a problem for me as well… I sometimes end up using Windows explorer to search for files after looking for a file list.
You could check your products tab, I usually forget to do this as I’m comfortable moving around in the content library.  I have Town and Country, for instance, which is spread out in the wardrobe smart content, but shows as a single group under products…. that’s a set I’m particularly fond of.
 Signature
My DeviantArt Galleries
My ShareCG Gallery
OPENSUBDIV Testing and Discussion
3Delight Surface and Lighting Thread
Profile
Posted: 16 December 2012 05:20 PM   [ Ignore ]   [ # 2 ]
Active Member
Avatar
RankRank
Joined  2003-10-09
Thanks, I forgot all about the Products list since I don’t normally use that.  That will help.
Profile
Posted: 16 December 2012 10:31 PM   [ Ignore ]   [ # 3 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
What I do is NOT import metadata after installing a new product.  I do a search for new content, it ends up in Unassigned, and I categorize it using my own system.  Only then do I import metadata for the product.
 Signature
FastGrab Alert Thread
Non-Genesis Items with Metadata
Plugin Version Numbers for DS 4.5
Updated Genesis Products
Products In Zips
Proud member of the Bald Wizards Club
Profile
Posted: 18 December 2012 07:47 AM   [ Ignore ]   [ # 4 ]
Administrator
Avatar
RankRankRank
Joined  2006-03-14
fixmypcmike - 16 December 2012 10:31 PM
This is about the only way to make it work for those of use who prefer our content structure to the default one.
 Signature
My Tutorials and Freebies Index
Profile
