Digital Art Zone
Subsurface Scattering ?
Posted: 16 December 2012 02:21 PM   [ Ignore ]
Member
Avatar
Rank
Joined  2009-10-02
How can i give an object a subsurface scattering material like a creme, banana or grapes ?
Profile
Posted: 16 December 2012 05:00 PM   [ Ignore ]   [ # 1 ]
Active Member
Avatar
RankRank
Joined  2006-05-26
Bryce doesnt have true SSS. It has translucency, but it can be rather fiddly to make it look like SSS and even then it will not be easy or should I say fast to render. In the other thread we talked about careful use of things like Ambience. This is one of those occasions where you might be forced to resort to ambience as other workarounds though better looking might be a render time killer. Best of luck.
Profile
Posted: 16 December 2012 08:04 PM   [ Ignore ]   [ # 2 ]
Active Member
Avatar
RankRank
Joined  2006-08-19
don’t make green grapes like I did, go with red/purple ones, they’re not as translucent,
 Signature
http://rarethdigitalmusings.blogspot.com/
http://rareth1966.deviantart.com/gallery/
Profile
Posted: 17 December 2012 03:41 AM   [ Ignore ]   [ # 3 ]
Power Member
Avatar
RankRankRank
Joined  2004-07-06
Roland4 - 16 December 2012 02:21 PM
If can be done but… as stated it will be time consuming and will need a bit of work.  Along these lines http://www.bryce5.com/details.php?image_id=4463&mode=search
With two objects, one for the outer surface using blurred transmission to break up the ray path through the material and a second object to “mop up” those rays which try to travel through the main body of the object.  All that remains then is rays that dip in and out of the model surface by interacting with the diffuse of the inner object material giving the impression of subsurface scattering.  In the example above, a volumetric material was used to give a very soft transition of density within - this combined with multiple light sources, a transparent outer material and blurred transmissions… resulted in a “longish” render.
 Signature
that Bryce Tutorials Info and this Products made by Horo and myself
Profile
Posted: 17 December 2012 04:04 PM   [ Ignore ]   [ # 4 ]
Member
Avatar
Rank
Joined  2009-10-02
@David
I have the same idea with two objects but my test fails. The dragon look´s very good, like ivory.
Profile
