You need the Symmetry command, which is in the Parameters pane option menu - either click the menu button in the pane’s top corner or right-click on the tab, or just press shift+Y. To mirror a whole pose select Root for the nodes, Recursive for propagation, Swap left and right for direction and Mirror Y/Z rotations for Trunk nodes. The other settings should be correct anyway.
