Digital Art Zone
2 of 3
2
Hexagon Crashes Constantly
Posted: 20 December 2012 06:41 PM   [ Ignore ]   [ # 16 ]
Member
Avatar
Rank
Joined  2011-04-25
*coughs*...So I did that thing…turned off OpenG and….I can UV map to my hearts content >_> I was on Hexagon for hours last night and not one crash. So I’ll keep working with Hexagon, getting my feet wet…
 Signature
My Deviantart account
Profile
Posted: 20 December 2012 08:04 PM   [ Ignore ]   [ # 17 ]
Power Member
Avatar
RankRankRank
Joined  2003-10-09
Hex is crashing a lot less for me now, it still goes once in a while, but not like it used to. Its actually getting pretty fun to play in hex
Profile
Posted: 03 January 2013 03:12 PM   [ Ignore ]   [ # 18 ]
New Member
Joined  2010-10-21
Had Hexagon crash on me seconds from starting, every time I tried. 2.5.1.79.  Ran Windows update, had 33 updates pending. Now it’s been stable for over an hour. smile
Profile
Posted: 04 January 2013 12:45 AM   [ Ignore ]   [ # 19 ]
Member
Rank
Joined  2011-09-27
I have been crashing every time I import anything into Hex from Daz. It runs fine then slows dramatically then crashes. When i create anything in Hex and export it into or import it into daz it doesn’t come in the same size as I modeled it, it is tiny and I have to bump to 1000. Sometimes.
When I make something and texture it in Hex and then import or export into Daz it is colorless. Sometimes it comes in with color and sometimes it doesn’t.
The last thing I have noticed after playing with it for about a month is that if you use the send to Daz option in the file menu it comes into Daz in several pieces, but if you export “save” it as a wavefont obj it doesn’t.  This doesn’t help adjust the size or help with the color problem though. I understand it is free and I have had a bit of fun with it although as I am getting more into modeling and more serious about my projects it is starting to make me yell at my monitor from time to time.
 Signature
I am the mother you always wanted your father to be
Profile
Posted: 04 January 2013 10:20 AM   [ Ignore ]   [ # 20 ]
Member
Rank
Joined  2009-01-27
bloodsnhall - 04 January 2013 12:45 AM
First a word about terminology. I don’t mean to be a grammar nazi, but proper terminology is critical for describing a problem.
You can’t “import” items into hex from DS. If you are using DS, you can export a model to hex, and if you’re in hex, you can export a model to DS. The only things you can “import” to a program are items saved on disk somewhere. And the only reason you can even “export” an item from one program directly to another one is through special software called a “bridge”.
Not sure at all what’s causing this. It may be inadequate hardware or system configuration. What are the specs for your system?
When i create anything in Hex and export it…[to]...daz it doesn’t come in the same size as I modeled it, it is tiny and I have to bump to 1000. Sometimes
This is probably due to mismatched “units”. In hex, look in “preferences”, “import/export” tab, “wavefront obj” button. The 4th item down is a “Unit of the file” setting. Tell us what that box says.
I don’t know what units DS uses or how to change them, so we need a DS guru to chime in here with that info. In the meantime, you can fiddle with hex’s units to see how that effects newly created model sizes when exported to DS.
When I make something and texture it in Hex and then…export [it to] Daz it is colorless. Sometimes it comes in with color and sometimes it doesn’t
We may need a DS guru here, as well.  grin
...if you use the send to Daz option in the file menu it comes into Daz in several pieces, but if you export “save” it as a wavefont obj it doesn’t
Caution here. You have to watch what’s happening. I don’t think you’re describing this accurately.
If you are running DS and you export genesis to hex, genesis appears in hex as a single object called “genesis”. There are no separate elements in the file for toes, fingers, abdomens, etc.
If you now save that model as an OBJ file, it saves it as that one piece. If you modify that figure and send it back to DS, then DS automagically recognizes it as a genesis “morph figure” and integrates the morph into genesis.
OTOH, if you’re in DS and export (save) genesis as an OBJ file, it saves that OBJ in “several pieces” such as “3_skinfoot”, “6_eyelash”, etc.
This OBJ file can now be imported into hex and modified. However, if you export that model out to DS, then DS sees it as a new figure, not as a genesis morph.
Moreover, if you send any articulated model (a model made up of “several pieces”) to DS, then DS recognizes the pieces but doesn’t know what to do with them. IOW, if you send an articulated poser model to DS, DS will recognize that it has a shoulder and a forearm, but if you try bending the arm, only the selected piece will rotate, not the whole arm. This model needs to be “rigged” to let DS know how the pieces move in relation to each other.
And PS:
DS does a sucky job at saving genesis as an OBJ file.
Go into DS and save out the genesis figure as an OBJ file. Now open that OBJ file in hexagon. Hide everything but the “7_tear” element and see how badly DS screwed it up. confused
ADD:
Curously, Roygee just made a post that makes an excellent addendum to this post and may be of great value to you. You can read it here: http://www.daz3d.com/forums/viewreply/211041/
 Signature
For any arguments or illustrations I give, my system specs are:
Hexagon version 2.5.1.79,  XP pro 32 bit,  pentium core2 duo,  ATI radeon 3870, 2 gigs ram
Profile
Posted: 16 January 2013 06:09 PM   [ Ignore ]   [ # 21 ]
Member
Rank
Joined  2007-01-25
I have noticed that the Tasselate tools make Hex crash a lot. I have trained myself to not use them (What is a bit of a pain) but Hex becomes a lot more stable.
Also only subdivide at the very end of your workflow if possible. After level 2 of subdivision is also gets cranky.
In my workflow I do all the initial modeling in Hex (that IMO is the best low poly modeler out there) and then I take the model into Silo 3D (that is very Hex like but a bit more complicated, and quite stable) and I do the final touches in Silo before taking the models into other tools for further details.
Silo can also detect some poly issues that you may not see in hex. Sometimes the mesh looks fine in Hex but Silo shows artifacts.
Just my 2 cents.
Profile
Posted: 22 January 2013 06:52 AM   [ Ignore ]   [ # 22 ]
Member
Rank
Joined  2006-11-17
BryonSpeller - 16 January 2013 06:09 PM
I have used Hexagon since 2.1. I have found the surface tessellation tool to be quite buggy with it removing polygons(more so on any n-gon). I always thought it was a problem from the original Eovia version that DAZ could not fix. However, after getting a copy of V1(free from an old magazine disk) I find that the problem with tessellation is not in V1.
From what I see. It looks like DAZ made some underlying changes to how Hexagon stores the model data in memory (to cut down on memory usage), which brought in various problems, including the tessellation bug. So it looks like that will never be fixed.
Profile
Posted: 22 January 2013 08:46 AM   [ Ignore ]   [ # 23 ]
Addict
Avatar
RankRankRankRank
Joined  2006-02-20
I was bold and used the 3GB / Large Adress Aware thingie on Hexagon (I have a 64bit Windows7) - that helped against crashes.
http://www.techpowerup.com/forums/showthread.php?t=112556
(It helped for Bryce too)
 Signature
I like Bryce, DazStudio, Poser and Vue ... in alphabetical order. And I would probably like Carrara too, if I could find the time to become acquainted with it. Peace?
Profile
Posted: 23 January 2013 03:05 AM   [ Ignore ]   [ # 24 ]
Member
Rank
Joined  2006-11-17
Hi Kerya,
Kerya - 22 January 2013 08:46 AM
That allows Hexagon to see/access more system memory, so although it may stop Hexagon running out of memory sooner, it does not in itself fix the issues of crashing. I have been using LAA on Hexagon for a 2-3 years.
To all:-
I do stand corrected on my last post. Although I do not see the issue with the surface tessellation in V1, it is present in the update V1.21 So that is something Eovia brought in. It just appears DAZ never fixed it.
One thing I am curious about. I now have various versions of Hexagon. What I have not seen yet is V2.0. Is there one? When I purchased Hexagon, it was at 2.1.
So at the moment it appears there is a gap between 1.21 and 2.1 (Maybe a V2.0 was never released as full version??)
Profile
Posted: 25 January 2013 05:43 AM   [ Ignore ]   [ # 25 ]
Member
Avatar
Rank
Joined  2005-09-15
@Steve,
Well I’ve poked about in my Downloads and found Hex 2.0 albeit part of the patched 2.1.  I have a vague recollection that 2.0 was released; to be fairly quickly followed by the patch and it was the originators that released it,  before Daz came on the scene.
Image Attachments
 Signature
Cheers, Fanners.raspberry
Profile
Posted: 25 January 2013 10:56 AM   [ Ignore ]   [ # 26 ]
Member
Rank
Joined  2006-11-17
Hi Redsquare,
Thanks for the info.
I will have to start looking again, to see if I can find V2.0
Profile
Posted: 25 January 2013 01:04 PM   [ Ignore ]   [ # 27 ]
Member
Avatar
Rank
Joined  2003-10-09
Steve athome - 25 January 2013 10:56 AM
Hi Redsquare,
2.0 was the one I first bought when it was released. The 2.1 fix was the last one that the Eovia team made before Daz took over it all.
2.1 is more stable then the 2.0 one. And it is also the only version I’m using that don’t crash.
 Signature
My store at Renderosity. http://www.renderosity.com/mod/bcs/index.php?vendor=29771
Rendo Freebies. http://www.renderosity.com/mod/freestuff/index.php?username=ghostman
Profile
Posted: 25 January 2013 01:14 PM   [ Ignore ]   [ # 28 ]
New Member
Joined  0
As a new user I don’t have a ton of experience to draw on, but I’ve noticed a trend relating to crashes. When my geometry is out of whack and I’ve got outside faces coming through each other and I apply smoothing, or try to bridge I can pretty much guarantee that I’ll see it crash. So my 2 cents worth of newbie advice, save before you use those features if there’s any chance your geometry is out of whack. Having said that, there are a number of times it’s crashed because as far as I can tell it just feels like it, and other times it’s quite well behaved.
Profile
Posted: 25 January 2013 01:34 PM   [ Ignore ]   [ # 29 ]
Member
Rank
Joined  2006-11-17
Hi Ghostman,
Ghostman - 25 January 2013 01:04 PM
When I purchased Hexagon, it was already 2.1 (not 2.0 + 2.1 patch). It is the version I use, as the later versions I find more problematic/buggy. (although 2.2 did fix some issues, it also brought in other bugs).
I think the main problems came in 2.5 when they added the DS Bridge (which appears to be the only upgrade they have ever made to Hexagon (in 6 / 7 years), well, apart from the sculpty primitives ROFLOL).
Profile
Posted: 25 January 2013 01:38 PM   [ Ignore ]   [ # 30 ]
Member
Rank
Joined  2006-11-17
stoltenkamp.scott - 25 January 2013 01:14 PM
I presume you are using the latest version, which is not stable.
One thing to watch for, is if Hexagon crashes, you should reset your preference file (or better, to actually remove/delete it)
You could save a copy of that file(if you have made changes), then you can just copy it back over when needed.
If the preference file becomes corrupted, it leads to unexpected problems. (something that DAZ are aware of, but never fixed). Not a problem I have ever seen in 2.1
Profile
2 of 3
2
