Digital Art Zone
Solo for U.N.C.L.E.  -  [WIP]
Posted: 03 June 2012 01:39 PM   [ Ignore ]
New Member
Joined  2004-01-18
Welcome in the U.N.C.L.E. thread dedicated to the 70th TV show Men from U.N.C.L.E..
The old original starting of this theme in old DAZ-site can be found here:  DAZ-old thread
Attention !  Hint !!  On the old forum archive the links to embedded images are broken. Thank you DAZ !  If you want to see that images you may play the manual wizard to display them by this following doings:
1. Find such a line in the text
<aa href=“postimages/origimage_1_2263158.jpg”>postimages/image_1_2263158.jpg</a>
2. copy this part
3. open a new browser window
4. and past the the copied portion behind the first part of the archive URL
http://forumarchive.daz3d.com/
5. so in total the link in the browser should read like this
http://forumarchive.daz3d.com/postimages/origimage_1_2263158.jpg
It’s just easy ... especially for one image ... Maybe someone may solve this also later. Otherwise without the images the old forum archive might be more or less worthless ...
All links from the old site about U.N.C.L.E. stuff will be found here in the heading message (plus the newly added stuff).
All Stuff is Poser-ready but should work also in D/S except that it might be neccessary to adjust the textures cause often poser procedurals are used. If not other named the stuff matches V4 and/or M4.
Cause it seems to be impossible to push images between text line (for the moment??) all images can be found at the end of the postings. And the sorting of the images is following the naming or other mysteries. So sorry for some mismatches.  Maybe this can be changed later (?).
So lets start the U.N.C.L.E. stuff ===>>>
Morphs and other stuff
The U.N.C.L.E. agents by SteveKitt  Solo and Kuryakin
and their weapon by SteveKitt  U.N.C.L.E. P38 Special
Following some images from the U.N.C.L.E. packages content.
Image Attachments
Profile
Posted: 03 June 2012 02:54 PM   [ Ignore ]   [ # 1 ]
Addict
Avatar
RankRankRankRank
Joined  2009-07-13
when I was a kid, my father loved that show!
he died when I was 10, I am now 50!
sure brings back memories!!
 Signature
WARNING do not click tongue rolleye what will be seen if you do cannot be unseen.
Profile
Posted: 03 June 2012 04:09 PM   [ Ignore ]   [ # 2 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
hey they are not bad likenesses.  I always preferred Illya Kuryakin to Naopoleon Solo, for some reason.
 Signature
Chohole’s Space        Neil’Vs Freebies and stuff        Bryce Rendering Challenge for June        June Freebie Challenge
11915 was the number
Profile
Posted: 03 June 2012 06:39 PM   [ Ignore ]   [ # 3 ]
Power Member
Avatar
RankRankRank
Joined  2004-08-24
Oh, this DOES bring back memories!  Loved that show!
Thanks for the morphs and such!
And Cho, you’re not alone smile  I loved Illya, - and David McCallum wink
 Signature
Cheers,
Alisa
Post Count - just add 6775 to what it says here smile
Coordinator & updater for KCTC Freebies *Remembering France*
Profile
Posted: 03 June 2012 06:57 PM   [ Ignore ]   [ # 4 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
I love every character David McCallum has played.
 Signature
FastGrab Alert Thread
Non-Genesis Items with Metadata
Plugin Version Numbers for DS 4.5
Updated Genesis Products
Products In Zips
Proud member of the Bald Wizards Club
Profile
Posted: 03 June 2012 07:33 PM   [ Ignore ]   [ # 5 ]
Active Member
Avatar
RankRank
Joined  0
I used to have the full Uncle gun set, in the briefcase! It had all the attatchments to make it into the rifle. it had an UNCLE pass, badge, and patch for your coat, a handgrinade, and a megaphone walkie talkie set. Then…one day, the main pistol from the set came up missing. I looked for it for weeks, I never did find it. I still think about where it could have gone. In fact, I told my wife many years ago, one day, about how I wish I could know where it went before I die. It has haunted me all my life…lol.
smirk
Image Attachments
 Signature
I am not this way because I am a musician, I am a musician because I am this way.
old posts: 10,322 Daz member since Build 1
Freebie Challenge Rules! - http://www.daz3d.com/forums/viewthread/286/
Profile
Posted: 03 June 2012 09:24 PM   [ Ignore ]   [ # 6 ]
Member
Avatar
Rank
Joined  2003-10-09
It was my favourite show when I was a kid, later shared the top spot with Star Trek when it appeared on the scene.
Picked up the complete series on DVD from TimeLife a while ago, it’s still available at a reasonable price:
https://www.timelife.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=1001&catalogId=10001&productId=19001
—Walt Sterdan
Profile
Posted: 04 June 2012 07:57 PM   [ Ignore ]   [ # 7 ]
Member
Rank
Joined  2006-04-08
Just an FYI- the grip on the pistol is too deep. It’s just a P-38 with the barrel chopped and a muzzle brake nailed on.
..Joe
 Signature
“Some people are like a Slinky… not really good for anything, but you still can’t help but smile when you shove them down the stairs”
Profile
Posted: 05 June 2012 08:26 AM   [ Ignore ]   [ # 8 ]
New Member
Joined  0
Joe Gerardi - 04 June 2012 07:57 PM
..Joe
Hi folks,
Joe Gerardi,you are correct,the gun is indeed a P-38,but it was modified for the show with a replacement handgrip as well as the replacement barrel,which is why it looks different to the standard P-38.I found this out as there are folks out there with the original props and found some excellent profile pics in the course of my research.I also discovered that the grips had the initials of the operative’s last name at the bottom.This is also recreated in my model for DAZ/Poser.I gather the pilot episode used a different gun,but as the budget got a bit bigger for the subsequent series,they were able to use the P-38’s instead.
I also had an U.N.C.L.E. gun as a kid,again,it was a luger instead of the P-38,and it was also painted gold.It was taken from me by my folks when i bopped my sister over the head with it.
Now,the INJ/REM models of the agents could do with a nice suit to wear,Any offers ? grin
Also a BIG thank you to JoEtzold for doing the works on transferring the old threads.Much appreciated.
Profile
