evilproducer - 16 December 2012 09:35 AM
I think what Joe is seeing is because the replicator is a tube, it lacks the perspective of a flat disk looked at slightly on edge.
I don’t think so, at least that wasn’t the point I was trying to make….
It’s about a sense of distance and relative size. In order for your rocks to appear, as they do, relatively the same size (going from left to right in your render), the ring would have to be very small. Whether it’s a torus or a disc or whatever, doesn’t really matter. It’s about the apparent size of the rocks as they get farther away from you. And when those distances are very large, the difference in apparent sizes should be much greater.
Consider this…
Let’s say the planet was 1,000 miles in diameter. Heck, I dunno, pick a number. Which means that the rings have a lot bigger diameter than that. Let’s call it 2,000 miles in diameter. That’s about 2/3 the distance from NY to Los Angeles. Big.
Now, if you had big rocks floating around in that 2,000 mile diameter ring, there would be huge distances between them. And if you pulled up in a spaceship and saw them, it would be kinda like you standing on your roof in Wisconsin (?) and looking at a house in Chicago.It would look a whole lot tinier than your house looks.
Bad example, but maybe you get the point. My initial impression was that it was a really small ring around a really tiny planet, so much so that it looked, well, wrong. Not consistent with planets and vast distances and space stuff.
Like I tried to mention in another post, the biggest challenge, IMO, with space images is trying to convince the viewer of size and distance. To show big planets and relatively small space ships and huge distances you need to give the viewer some perspective. Just having a spaceship next to a planet doesn’t give them any clue about how big stuff is. However, as RoguePilot so clearly illustrated in a couple of his images, when you insert some additional ships that are tiny specks in the distance, the viewer immediately gains a sense of perspective and distance. Otherwise people are searching for clues, and subconsciously get confused and unsatisfied.
