fixmypcmike - 20 December 2012 09:10 PM
GSE 1.9 (and I believe 1.11) do not include some of the items which more appropriately should be in the application installer—possibly UberEnvironment?
Just at a glance, I can’t see that anything has been left out or added from previous installers. As far as omniFreaker’s stuff goes, it still includes UberAreaLight, UberEnvironment2, SimpleSurface, UberSurface, and UberVolume. The base Genesis figure seems to have all the usual functionality, although I have noticed for the last two or three versions, that Genesis seems to have mesh smoothing turned on, even if it doesn’t show so in the Parameters tab. Load Genesis and start bending its joints, and you’ll see the mesh snap into place when you’re done—it didn’t use to do that, as I recall. The first screenshot is of Genesis as I’m making the bend, and the second screenshot is of Genesis after I’ve made the bend, and you can clearly see the difference in the mesh between its transition and final pose.
Click thumbnail to see full-size image
