Digital Art Zone
Copying a pose from a magazine
Posted: 11 December 2012 03:53 AM   [ Ignore ]
Member
Rank
Joined  2007-01-13
The answer to this may be, just get in and do it.
I want to copy a pose from a magazine so I can see it from other angles - has anyone got any hint or tips on doing this - a single photograph at an odd angle.
How I was going to tackle it was find a pose as close as possible from my library and then adjust it.
Thanks
Profile
Posted: 11 December 2012 04:08 AM   [ Ignore ]   [ # 1 ]
Power Member
Avatar
RankRankRank
Joined  2009-02-24
I think you’ve answered your own question there. There is no fast-track method for copying poses from an image besides eyeballing it and manually positioning the model into place. Use of poses can help sometimes, but whenever I work from reference I prefer to start with a zeroed figure. That said, I generally work with the sliders to create poses rather than the click-drag method. It’s a lot more accurate and doesn’t move any part of the body you don’t want to move.
 Signature
Here be dragons
Profile
Posted: 11 December 2012 04:09 AM   [ Ignore ]   [ # 2 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-15
Tarak - 11 December 2012 03:53 AM
Thanks
That is the only way I think, I don’t know of any fancy techie solutions smile
You could always load your image either as a Background, or apply it to a Plane Primitive so that you can see it while you are moving limbs and things.  If it is applied to a Plane, you could adjust the opacity in the Surfaces pane to help you see it better?
Profile
Posted: 11 December 2012 05:48 AM   [ Ignore ]   [ # 3 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
We actually had a New Users COntest about this, and there are quite a few hints and tips within the WIP thread here http://www.daz3d.com/forums/viewthread/3450/
 Signature
Chohole’s Space        Neil’Vs Freebies and stuff        Bryce Rendering Challenge        Freebie Challenge
11915 was the number
Profile
Posted: 11 December 2012 06:23 AM   [ Ignore ]   [ # 4 ]
Member
Rank
Joined  2007-01-13
Thanks chohole - that is goddam a near text book on the subject smile - thanks Herald and Jimmy also smile  Now all I need is a stable version of DAZ 4.5, mine crashes on start-up :(
Profile
Posted: 11 December 2012 09:04 AM   [ Ignore ]   [ # 5 ]
Addict
Avatar
RankRankRankRank
Joined  2011-12-10
Tarak: Have you discovered Power Pose yet?  You have it.  It’s amazing to me how easy it is to make poses using that when you have the Power Pose tab open across from Parameters.
I’ve been taking characters from their default pose and getting a halfway decent base pose in about five minutes.
 Signature
My DeviantArt Galleries
My ShareCG Gallery
OPENSUBDIV Testing and Discussion
3Delight Surface and Lighting Thread
Profile
