Where do I find 3DP’’ scaling preset in DS4.5? I looked everywhere.
Hello!
You will find them in the Content Library. Just follow this path:
People -> Genesis -> Characters -> 3DP -> Scaling Presets
Enjoy!
============ Someone asked once why we vendors put our names on files/folders. That person believed it was to make sure you did not forget the vendor’s name. I don’t know why others do it, but truth is, I do it so I can find everything with ONE search without missing files. (Though I do not usually put my initials on files, just folders.) Great if I have to update or whatnot. Perhaps not so great if you are just looking for Scaling Presets. That’s why commercial sets come with file lists.
Just to stick my nose in, sorry, bad habit. I usually check a zip or rar file to see what the file structure is. good way to check if I should install to DAZ My Library or Poser runtime. DAZ store stuff is usually an exe so I just go with the default and hope it has a readme web page to tell me were to look for the new goodies.
If there is a file name other than Poser whatever or Studio whatever above Runtime or My Library, I just change the name and then unzip to a level higher. This helps me keep my file structure the way I want it.
Thanks to everyone! Additional kudos to 3dP for the Legacy version. Not everyone’s moved on to 4.5 for various reasons (system requirements, bugs, comfort zone, etc.). So this is really appreciated!
Thanks, DestinysGarden and 3DProclivity, these look fun! And thanks for the update, Sickleyield.
One minor issue - the Alien heads for Genesis both appear to be the exact same file. Same file names inside, same size same date
By both, you mean the Legacy & the DS4.5 versions? Yes, it is odd. I noticed that too but I assure you the non-legacy files will NOT work in DS4. I tested them. And it kind of makes sense that they are the same size since the only difference between them is the program used to import them (same obj’s loaded into morph loader pro, same file names, same parameters, same morphs, etc.).
Same date? That’s odd…could someone with DS4 PLEASE test these to be sure I didn’t just upload the wrong file? Thanks.
You’re welcome. And I understand. I just moved to DS4.5 myself and still miss Finder II from version 3!
