Digital Art Zone
Daz 4.5 Install to Secondary Drive
Posted: 09 December 2012 11:12 AM   [ Ignore ]
Member
Avatar
Rank
Joined  2007-12-12
I just finished a new computer build and have installed my Daz Studio 3A as adamr001 outlines in this archived post http://forumarchive.daz3d.com/viewtopic.php?t=153483
My questions are before I go messing up everything:
• Can you follow this same method to install Daz Studio 4.5?
• Do you need to also install the 32 bit version of DS 4.5 side by side with the 64 bit or is the 64 bit version enough?
• Does it hurt to include both and is there an advantage?
The OS will be Windows 7 Home Premium.
 Signature
Specs: Win7 x64 • Gigabyte GTX 570 • Gigabyte P45T-ES3G • Intel Core2 Quad 3.0ghz • 16gb Ram
Click For My Rendo Gallery Old Post Count 910
Profile
Posted: 09 December 2012 11:52 AM   [ Ignore ]   [ # 1 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-15
cipher_X - 09 December 2012 11:12 AM
DS 4.5 uses as default, a folder called ‘My Library’ instead of one called ‘Content’, but you can call it whatever you like.  Just make sure you know that when an installer wants to install to My Library, that you use your own named folder instead.
There is no need to install both the 32 bit and 64 bit versions, but you can if you wish.  I don’t know of any advantage, I used to have the 32 bit version installed as well, but I only onstalled the 64 bit version of Ds 4.5.1.6.
Profile
Posted: 09 December 2012 12:16 PM   [ Ignore ]   [ # 2 ]
Member
Avatar
Rank
Joined  2007-12-12
JimmyC_2009 - 09 December 2012 11:52 AM
Thanks JimmyC_2009,
My idea was to keep the older content Poser/DS in the normal content/runtime/etc structure and then us the My Library that DS4.5 creates for anything new that pertains just to Genesis..V5…M5, etc.
The way I started grouping my runtimes in DS3 was to have:
content
          >runtime
                    >libraries
                                >characters
                                              >Victoria4
                                                        >clothes
                                                        >hair
                                                        >shoes
                                              >Michael4
                                                          >clothes
                                                          >hair
...etc for each character, under each category. It just seemed to be easier to locate things so I want to keep that the way it is.  grin
 Signature
Profile
Posted: 09 December 2012 12:30 PM   [ Ignore ]   [ # 3 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-15
There is no reason why you can’t still do that.  I have loads of Poser runtime folders which I just list inside DS 4.5, and they show up OK.  It is a good idea to keep the My Library folder for Genesis stuff I think, although, I put everything new in there now, as most of it is Genesis anyway.
If you have any problems, just post again, but your ideas sound good to me.
Profile
