Digital Art Zone
Luthbel!!!    Way of the samurai   Pleaseeeeeeeee
Posted: 08 December 2012 01:25 PM   [ Ignore ]
New Member
Avatar
Joined  2011-07-27
I would ike Luthbel to update Way of the samurai. For DSON so that I can use it in poser.
Profile
Posted: 08 December 2012 10:02 PM   [ Ignore ]   [ # 1 ]
Member
Avatar
Rank
Joined  2004-10-09
TaishoBee - 08 December 2012 01:25 PM
You can easily do it yourself. Here is the outfit on Micheal 5 in Poser Pro 2012. It took about two minutes to do the conversion in DS4.5. All you need to do is load the outfit on base genesis, save as wearable preset, select generate Poser companion file and you are done.
It is so easy and fast that I haven’t even bothered to download and reinstall items that have been updated. I just do the conversion when I need them. If you need help with any step, let me know.
Ciao
TD
Image Attachments
 Signature
I reject your Reality and substitute my Vue!
Check my gallery at DeviantArt
Profile
Posted: 09 December 2012 01:15 PM   [ Ignore ]   [ # 2 ]
New Member
Avatar
Joined  2003-10-09
Thanks Thd777,
Do the imported clothes also follow the Genesis body morphs automatically when in Poser? Like if you morph the Genesis figure into a V4 body type… will the samurai suit do the same?
Thanks
Profile
Posted: 09 December 2012 02:16 PM   [ Ignore ]   [ # 3 ]
Member
Avatar
Rank
Joined  2004-10-09
ColemanRugh - 09 December 2012 01:15 PM
Thanks Thd777,
Thanks
It is not fully automatic in Poser like it is in DS, but the DSON importer comes with a script that does the job. You find it under Scripts -> DSON support -> Transfer active morphs. So all you need to do is the dial up your morphs and then run the script. It works mostly quite well.
Ciao
TD
 Signature
Profile
Posted: 09 December 2012 02:32 PM   [ Ignore ]   [ # 4 ]
New Member
Avatar
Joined  2003-10-09
Thanks for the help!!  smile
Profile
Posted: 10 December 2012 08:39 PM   [ Ignore ]   [ # 5 ]
New Member
Avatar
Joined  2011-07-27
thd777 - 08 December 2012 10:02 PM
Ciao
TD
Hmm when I click the clothes to bring them into the scene in daz, an error pops up and says it’s missing a geometry? I checked and they are all where they belong.
Profile
Posted: 10 December 2012 10:35 PM   [ Ignore ]   [ # 6 ]
Member
Avatar
Rank
Joined  2004-10-09
There was an update for the samurai set some time ago. The version I have works in DAZ studio 4.5 and is labeled as wayofsamurai1.3. If you do not have that one, reset your downloads and get it. If you do have that one, what version do DS are you using?
TD
 Signature
Profile
Posted: 10 December 2012 10:52 PM   [ Ignore ]   [ # 7 ]
New Member
Avatar
Joined  2011-07-27
thd777 - 10 December 2012 10:35 PM
TD
I have the newest version of Daz Studio, I always update it.
I’m not sure what version of the outfit I have. I’ll check and update it if I need to. I wish I’d get notifications when they are updated.
Edit. I attached a screenshot of what is happening.
Image Attachments
Profile
