Digital Art Zone
2 of 2
2
How to clone a horse
Posted: 08 December 2012 04:22 PM   [ Ignore ]   [ # 16 ]
Power Member
Avatar
RankRankRank
Joined  2007-12-25
After a lot of fiddling and trial-and-error, I ended up angling the D-Former a bit, and narrowing the width (x axis) to pull in the sides a bit.
Image Attachments
Profile
Posted: 08 December 2012 04:25 PM   [ Ignore ]   [ # 17 ]
Power Member
Avatar
RankRankRank
Joined  2007-12-25
Also, although I had previously used the scale controls to increase the Y axis on the abdomen, I ended up setting that back to 100% because it interfered with the D-Former, and I liked how the D-Former looked better.
Next I worked on the belly/groin area. This also took some tweaking, and I ended up reducing the x-axis of the field quite a bit to avoid distorting the legs.
Image Attachments
Profile
Posted: 08 December 2012 04:29 PM   [ Ignore ]   [ # 18 ]
Power Member
Avatar
RankRankRank
Joined  2007-12-25
Even though D-Formers are attached to the root node and can cross body part boundaries, you’ll often find them easier to control if you don’t try to do too much with a single D-Former. I found that I really needed separate ones for the chest and belly.
The last thing I did today was make the rump bigger, overall, but then nudge in the “hips” a bit.
Then I had to duplicate the work on the other side of the body. I used “copy selected items” and “paste to selected items” to get the parts of the D-Former into the same position as the one on the right, then reversed the x-trans and z-rotation to move them to the left side.
More later—I need to go make supper! smile
Image Attachments
Profile
Posted: 08 December 2012 09:46 PM   [ Ignore ]   [ # 19 ]
Power Member
Avatar
RankRankRank
Joined  2007-12-25
Ok. I exported the altered beastie as an obj, brought it back in as a morph, did the Freeze ERC thing with the appropriate pose, but I’m having some scaling and translation problems with the final result.
Here’s the result now…. with just a bit of cheating. Namely, I loaded the saddle and bridle, fit them to Horse 2, chose the clone Charger, let the refit happen… and then unfit the saddle and bridle and translated and scaled the horsie to get them back on to the horse. The saddle fit is much better than just repositioning the saddle: the green version is the refit saddle, the pink is the original. The bridle, not so much.
So I’m not going to be posting the process until I manage to figure out what I’m doing wrong here. A couple of things have changed in DS 4.5 about how clones are handled, and I didn’t have translation concerns with my previous clone attempts. But I’ll get it figured out… eventually. wink
Image Attachments
Profile
Posted: 09 December 2012 12:44 AM   [ Ignore ]   [ # 20 ]
Active Member
Avatar
RankRank
Joined  2005-03-26
Will these techniques work for human shapes to Genesis, too?  (I’m thinking Sixus1’s Behemoth, HER, and Scrum, just to start with…)
 Signature
God still reigns.
As a cultural historian, Dawson understood that the core of a culture is found once we locate the thing that the culture would never relinquish, or even imagine itself relinquishing. I submit that in our case it is not individual liberty, or sex, and certainly not religion. It is not even the machine. Rather, it is the machine insofar as it promises an activity superior to the human act. ~ RUSSELL HITTINGER
http://eustacescrubb.deviantart.com/gallery/
Profile
Posted: 09 December 2012 08:49 AM   [ Ignore ]   [ # 21 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Why did you do an ERC freeze? A clone shape shouldn’t adjust the rigging, as far as I know, but should simply reshape the mesh. If you did adjust the rigging to the new shape that may in part account for your problems with the converted items.
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 09 December 2012 08:50 AM   [ Ignore ]   [ # 22 ]
Power Member
Avatar
RankRankRank
Joined  2007-12-25
Eustace Scrubb - 09 December 2012 12:44 AM
Yes. You want the same number of arms and legs, and remember that a clone shape and AutoFit will convert the confirming item to use the Genesis rigging, so if there were extra bones in the other figure, you’re not going to still have them when the conformer converts to Genesis.
Also, if you’re thinking of making an actual shape to replicate a non-Genesis figure to use in a render, unless you are the creator, you won’t be able to distribute it. The likeness of an original character belongs to the creator.
Profile
Posted: 30 December 2012 05:02 PM   [ Ignore ]   [ # 23 ]
Addict
Avatar
RankRankRankRank
Joined  2007-11-06
...fascinating.  Considering doing the same with the original Mavka so I can use the older figure’s clothing & props with the Genesis version as I have a fairly decent investment in the original character.
 Signature
...forsaken daughter is watching over you…
Profile
Posted: 30 December 2012 05:18 PM   [ Ignore ]   [ # 24 ]
Addict
Avatar
RankRankRankRank
Joined  2004-08-11
There should be a link for this in Nuts-N-Bolts forum!
 Signature
—-Wolff On The Prowl—-
Posts: 28,985 and counting!
        RAMWolffsWorld
Profile
Posted: 10 April 2013 06:56 PM   [ Ignore ]   [ # 25 ]
Member
Avatar
Rank
Joined  2008-09-17
so is the obj you save and imported as a morph the clone?
can that be used in the auto fit?
im looking to make a clone for autofit .
 Signature
www.bloodyrosesdesigns.com
The Aldara Project
Profile
Posted: 11 April 2013 07:38 AM   [ Ignore ]   [ # 26 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Yes, import as a morph and set it’s type to Modifier/Clone
 Signature
Profile
Posted: 11 April 2013 06:16 PM   [ Ignore ]   [ # 27 ]
Member
Avatar
Rank
Joined  2008-09-17
thanks
ss
 Signature
The Aldara Project
Profile
Posted: 12 April 2013 12:31 AM   [ Ignore ]   [ # 28 ]
Power Member
Avatar
RankRankRank
Joined  2007-12-25
Richard Haseltine - 09 December 2012 08:49 AM
I don’t know how I missed this post before. I should get back to this project now that I’m done teaching my double section of stats….
Profile
2 of 2
2
