Digital Art Zone
How to create light-emitting surfaced similar to “Arealight Plane”
Posted: 03 June 2012 01:22 AM   [ Ignore ]
New Member
Joined  2009-11-05
Hi. I am new to Daz Studio, and scratching my head over this issue. In one of the lighting presets, there is an object called “AreaLight Plane” and when this is included in a scene, the plane casts ambient light.
I need to create an identical object to this, and after some reading, believe that the way to accomplish this is by creating an object - another plane - and setting the ambient lighting to white, and the strength to 100%.  However, there should also be a way to set a flag so this object will emit might, which I cannot find anywhere in the settings (from the Surfaces [Color]- Editor - All tools) .
In short, I need to know how to turn an object into a light emitter.  Any help would be very much appreciated.
Regards,
Joe
Profile
Posted: 03 June 2012 03:27 AM   [ Ignore ]   [ # 1 ]
Member
Avatar
Rank
Joined  0
There is a lot more to surfaces then the default material will provide.  What you have done is to make a surface look like it is emitting light. The default material can not make a surface that actually emits light. If you click on “!Uber AreaLight Help” you will get a description on how to make a true light emitting surface. You can also make your own light emitter in Shader Mixer.
Cheers! Oom
Profile
Posted: 03 June 2012 08:22 AM   [ Ignore ]   [ # 2 ]
New Member
Joined  2009-11-05
Thanks for the tip on the Uberlight help!  I would not have found that myself.
Best regards,
JS
Profile
Posted: 03 June 2012 11:00 AM   [ Ignore ]   [ # 3 ]
Member
Avatar
Rank
Joined  2003-10-12
Oom Fooyat - 03 June 2012 03:27 AM
Cheers! Oom
Is there a tutorial on creating light-emitting surfaces in Shader Mixer somewhere? I must have missed that part?
Profile
Posted: 04 June 2012 10:52 AM   [ Ignore ]   [ # 4 ]
Member
Avatar
Rank
Joined  0
Don’t remember if I actually tried it myself yet. red face In the sticked thread “List of Shader Mixer Tutorials and Recipes” at the top of the page, there is a link, under recipes, to a post at the old forum, named “Fun with area lights”.
I think there is a script somewhere on the General Freepozitory that restore old threads to html with pics.
Oom
Profile
Posted: 04 June 2012 01:04 PM   [ Ignore ]   [ # 5 ]
Active Member
Avatar
RankRank
Joined  2007-01-08
Georgehaze - 03 June 2012 11:00 AM
If your surface already has a texture applied:
-Open Shader Mixer
-File->Import From Scene->and select “Material” from the drop-down (it’s the default).
-Go to the brickyard->Roots->Lights->Area Light.
-Plug the texture you use in Diffuse into the Light Colour of the area Light brick.
-Apply
You’ll need to adjust a few things:
1) DS primitives appear to have normals pointing inward so scale them negatively once (e.g. scale the sphere in X scale -100%)
2) If you leave Decay at the default value of 1 (real world physics value is “2”), and you have an Intensity of 10, all textures you use will probably be whitewashed, so reduce intensity somewhat.
3) be wary of the default number of samples, not conducive to test renders. wink
Profile
