Digital Art Zone
Poke poke poke poke poke
Posted: 05 December 2012 07:17 AM   [ Ignore ]
Active Member
Avatar
RankRank
Joined  2012-08-31
How is it that I can have pokethrough in a render, but not is the OpenGL preview?
Profile
Posted: 05 December 2012 08:44 AM   [ Ignore ]   [ # 1 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Often that’s down to displacement, which doesn’t show in preview.
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 05 December 2012 04:35 PM   [ Ignore ]   [ # 2 ]
Active Member
Avatar
RankRank
Joined  2012-08-31
But I have no displacement map on the item.
Profile
Posted: 05 December 2012 04:58 PM   [ Ignore ]   [ # 3 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Or on Genesis (or whatever the wearer is)?
 Signature
Profile
Posted: 05 December 2012 05:53 PM   [ Ignore ]   [ # 4 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
Also…have you moved anything before hitting render?
You may have to wait for the smoothing to finish calculating…
 Signature
1432 old posts
My ShareCG gallery.
Just because something costs a lot, doesn’t mean it’s the best…
It just means it’s expensive.
Profile
Posted: 05 December 2012 06:16 PM   [ Ignore ]   [ # 5 ]
Active Member
Avatar
RankRank
Joined  2012-08-31
I hadn’t applied a smoothing modifier because it appeared that the outfit didn’t have any poke through issues in the OpenGL preview.
When I apply the smoothing modifier it just makes things worse as the poke through appears in the preview and I have to crank the modifier up so high to get rid of it that it becomes useless. I guess I’ll just have to bite the bullet and remodel the outfit. It just seems so weird that it would look perfectly fine in an OpenGL rendering but then look like crap when given a high quality render.
Profile
Posted: 05 December 2012 06:23 PM   [ Ignore ]   [ # 6 ]
Active Member
Avatar
RankRank
Joined  2012-08-31
Ha! I figured it out. Somehow in the Mesh Resolution I had accidentally turned on “soft corners and edges.”. Made it sharp and now it’s working fine.
Profile
Posted: 05 December 2012 07:22 PM   [ Ignore ]   [ # 7 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
Well…I guess that’s something else to look for.
 Signature
1432 old posts
My ShareCG gallery.
Profile
Posted: 05 December 2012 07:35 PM   [ Ignore ]   [ # 8 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
also try using “Transfer Active Morphs”
 Signature
Pete
Community Volunteer:
If by some miracle I express an opinion then it is my own and not that of Digital Art Zone.
Somethings to Consider when starting to learn CG
My Render Thread
Proud member of the Bald Wizards Club
Profile
Posted: 05 December 2012 08:55 PM   [ Ignore ]   [ # 9 ]
Active Member
Avatar
RankRank
Joined  2012-08-31
mjc1016 - 05 December 2012 07:22 PM
Yeah I must have accidentally set that. It’s not a function I normally use, or even know what it does exactly…. except produce poke-through.
Profile
Posted: 05 December 2012 09:27 PM   [ Ignore ]   [ # 10 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
ghastlycomic - 05 December 2012 08:55 PM
You set smoothing…and that is part of the smoothing.
Basically it’s the same function as ‘bevelling’/filleting/creasing an edge in a modelling program…it preserves the edge ‘hardness’ (makes the edge sharp as opposed to soft and flowing).
 Signature
1432 old posts
My ShareCG gallery.
Profile
