Digital Art Zone
V4 and Amarseda hair
Posted: 04 December 2012 09:52 AM   [ Ignore ]
Active Member
Avatar
RankRank
Joined  0
When I add the Amarseda hair to V4 it doesn’t quite cover at the front hair line I have tried to move it various ways and still cant hide the original hairline on V4, also am i supposed to use fit to on it because that didn’t work either.  Also am not sure how to group or parent an item.  Help anyone?
Profile
Posted: 04 December 2012 10:36 AM   [ Ignore ]   [ # 1 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-15
You need to get rid of the base V4 skin with the purple bikini.  If you go to the Poses folder you should find at least a base resolution texture.
You should always use the ‘Fit To’ option for hair, that way it will move with the figure and stay in place, there is then no need to parent the hair.
Profile
Posted: 04 December 2012 10:37 AM   [ Ignore ]   [ # 2 ]
New Member
Avatar
Joined  2012-11-04
Hi.
I used to have the same problem, until I saw I didn’t selected the right Amarseda file.
Are you sure you selected the V4 version?
If you didn’t do it, be sure you have associated the hair with the character (“Fit to” option”).
Profile
Posted: 04 December 2012 11:14 AM   [ Ignore ]   [ # 3 ]
Active Member
Avatar
RankRank
Joined  0
Thanks It was for sure the hair for V4 I checked that first so I will try a different texture ( why didn’t I think of that *smack*)  smile
Profile
Posted: 04 December 2012 11:54 AM   [ Ignore ]   [ # 4 ]
Addict
Avatar
RankRankRankRank
Joined  2011-12-10
YOu could always apply the Lana textures that the Genesis female wears onto V4… they’ll work.
 Signature
My DeviantArt Galleries
My ShareCG Gallery
OPENSUBDIV Testing and Discussion
3Delight Surface and Lighting Thread
Profile
Posted: 06 December 2012 09:15 AM   [ Ignore ]   [ # 5 ]
Active Member
Avatar
RankRank
Joined  0
thanks got that working now…I’m sure learning this program is going to be very slow going
Profile
Posted: 06 December 2012 09:28 AM   [ Ignore ]   [ # 6 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
Kharma - 06 December 2012 09:15 AM
Yes it does take time to learn and we all learn at different speeds…just try not to run before you can walk, aim low to start with.
 Signature
Pete
Community Volunteer:
If by some miracle I express an opinion then it is my own and not that of Digital Art Zone.
Somethings to Consider when starting to learn CG
My Render Thread
Proud member of the Bald Wizards Club
Profile
Posted: 06 December 2012 09:36 AM   [ Ignore ]   [ # 7 ]
Active Member
Avatar
RankRank
Joined  0
I am learning a bit at a time, lighting and camera angles will be a huge challenge i am sure
Profile
