Digital Art Zone
Illumination options
Posted: 03 December 2012 09:38 PM   [ Ignore ]
Member
Rank
Joined  2011-08-12
Hi
In Daz studio 4 you can change a individual lights illumination to diffuse only or specular only, how do you do this in Carrara?
any help would be appreciated
thanks
Profile
Posted: 04 December 2012 08:59 AM   [ Ignore ]   [ # 1 ]
Power Member
Avatar
RankRankRank
Joined  2004-08-24
There is no such thing a specular light and /or diffuse light in the real world
these are properties of the object / material and its Highlight and Shininess strengths or maps.
if you want objects glossy or dull in a specific areas you can create a grey-scale image and add it to the shininess
hope it helps smile
Profile
Posted: 04 December 2012 09:08 AM   [ Ignore ]   [ # 2 ]
Power Member
Avatar
RankRankRank
Joined  0
You can’t. Carrara’s specularity is controlled in the shader of the object, not the light. This is a fundamental difference in Poser/DS and most of the rest of the 3D world…
If you have PRO you can render out separate Multi-Pass layers for Diffuse and Specularity.
HDRI / Image-based Lighting (IBL) creates non-directional light without specularity. (any of the Global Illumination options on their own generally do not create specularity, I believe)
You can control specularity in each shader. It is a 2-channel control the first called HIGHLIGHT which controls the color and pattern and uses the UV map (if you have a specular map put it here).... The second channel is called SHININESS and it is a single value (best controlled with a VALUE 0-100 shader) that focuses the specularity according to the angle of the light. Lower numbers spread the specularity across the object, higher values focus the specularity to a narrow angle…. I have a video tutorial on my website called “Creating Skin Specularity” or similar… Link to my site is in my sig below…
 Signature
grab a cup and hang with us at My CAFE - CARRARA USERS GROUP
Tutorials and stuff - 3d.wetcircuit.com
Profile
Posted: 04 December 2012 09:20 AM   [ Ignore ]   [ # 3 ]
Active Member
Avatar
RankRank
Joined  2007-08-14
Shaders Plus appears to have this feature.
 Signature
These are not the tutorials you’re looking for. Move along.
My old profile
Profile
Posted: 04 December 2012 10:36 AM   [ Ignore ]   [ # 4 ]
Active Member
Avatar
RankRank
Joined  2003-10-09
Holly’s video tute on specularity is highly recommended along with her other tutes! smile
Profile
