yes,, barbuit is right,,if save as scene , and load it,, the generated morph of the sunglass value may return default. in ds 4.5(not beta)
but if you set the morph (not generated morph of the sunglass, the morph of character(genesis)
option “auto-follow” check off, in parameter setting,, then save it as scene,
ds 4.5 duf scene keep the status of morph (which cause the problem)
and if you hope , you can save it as modified assets, but it is not good plan to change morph statas and save it,,,
so I recommend, save character as scene or scene subset .
1 as Richard and barbuit said,, adjust generated morph of the accessory or hair,, value to zero.
2 the morph of the genesis, change option “auto-follow” “check off” in parameter setting .
3 save the scene. and save the figure(genesis) as scene subsets.
the subsets of the figure, can keep the morph setting (not auto follow) too.
so it can not cause problem when apply or sunglass on the character, I believe.
and it can work only for the genesis when you load the subsets.
