Digital Art Zone
Another question: moving body while keeping limbs locked in place?
Posted: 01 December 2012 08:09 PM   [ Ignore ]
Active Member
Avatar
RankRank
Joined  2003-10-09
Sorry to ask another question, but I thought I already knew how this worked and it’s not working for me.  wink
Is there a way to lock, for example, a figure’s hand, forearm, and upper arm so that if the chest is moved, those locked parts are not moved along with it? Kind of like what happens when you lock the body and then drag an arm with IK on? Basically the arm is positioned the way I want it but the rest of the body is not. I thought locking the parts in the Parameters panel would do it, but it seems to do nothing.
As always, thanks in advance for any help.
 Signature
“It answers all the questions, finally, but not really, but kind of”
- Bob Denver
my deviantArt page: http://snowsultan.deviantart.com
Smacky icon by Xamag
Profile
Posted: 02 December 2012 01:10 AM   [ Ignore ]   [ # 1 ]
Power Member
Avatar
RankRankRank
Joined  2012-03-24
Hi,,Snow Saltun,, do you usually use the pin tool on node which you fix,
then moving other node with universal tool?
It can work, but not good,, manytimes when I move other node much (not so much,, just more,,)
, the pinned node easily move too,,^^;  so I do not like,, ds pin system. not rely on much ^^;
but about active pose tool,, it work better,, @@;
open active pose tool, then select bone icon (it is not joint editor icon^^;)
then select node which you want to fix translation,,
then in tool setting tab, click “Toggle pins” there have option how to rock the pin.
(bone origin, bone end ,bone both,)
then “on” transform gizmo,,  and select other bone, which you want.
but,, while you use the Active pose tool,, you can not use other tool,
one caution,,,
while you pinned the rig by active pose tool,
then you change tool to universal rotation,, move or rotatie another rig.
after that,, you may return active pose tool,,now translation gizmo have gone somewhere,
and you can not find the pin and clear it @@;
in this case, in scene tab, and deselect all,, then select again genesis.
you can find the pin and gizmo^^; but I like this pozing tool ,it much better than,, usuall universal tool and pin,,
I hope you try active poze tool ^^
(I knew this tool,, when jaderlail answer for othe user question ^^)
Image Attachments
Profile
Posted: 02 December 2012 01:30 PM   [ Ignore ]   [ # 2 ]
Addict
Avatar
RankRankRankRank
Joined  2011-12-10
I know in Poser you could Parent a hand or a foot to an object with IK and do this… I’ve no idea how to do it in DS…  Poser has had that feature since at least Version 3.
 Signature
My DeviantArt Galleries
My ShareCG Gallery
OPENSUBDIV Testing and Discussion
3Delight Surface and Lighting Thread
Profile
Posted: 02 December 2012 02:09 PM   [ Ignore ]   [ # 3 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
Pinning is the way to go in DS. But remember do all the posing with pins on, then Pin the part you just did then pose more. When you swap back to any other posing tool the pins are turned off. Pin pose then pin more pose more pin more. Only switch out of pinning when you are finished with the full PINNED pose.
EDIT, as said this is done with the Active Pose Tool.
 Signature
My art on DeviantArt and my Project The Primitives a year in the life.
Father of the Stupid threads, find the Stupid you need here.
I may not be worth much but most people tell me my two cents were well spent
Proud Member of the Bald Wizards Club.
Profile
Posted: 02 December 2012 02:46 PM   [ Ignore ]   [ # 4 ]
Addict
Avatar
RankRankRankRank
Joined  2011-12-10
LOL… I am sooo ignorant of the more obscure features of DS… every time I turn around there’s something new to learn smile
 Signature
My ShareCG Gallery
Profile
Posted: 03 December 2012 03:37 AM   [ Ignore ]   [ # 5 ]
Member
Avatar
Rank
Joined  2005-08-25
at the moment this is not working!
Daz knows about this IK/FK problem…
a future request was been made here:
https://bugs.daz3d.com/view.php?id=41253
it’s assigned, so daz is hopefully working on this problem.
 Signature
DAZSTUDIO FUTURE REQUESTS - CLICK ME TO JOIN
Feel free to join, sign and vote for dazstudio future improvements.
(550 users and still counting up to 1000) would like to see improvements, and you?
What features would you like to see appear in dazstudio 5?
Profile
Posted: 03 December 2012 04:11 AM   [ Ignore ]   [ # 6 ]
New Member
Joined  2012-09-22
Jaderail - 02 December 2012 02:09 PM
I’m a bit curious about the reason you should not switch back and forth between pins on and off?
Profile
Posted: 03 December 2012 05:22 AM   [ Ignore ]   [ # 7 ]
Power Member
Avatar
RankRankRank
Joined  2012-03-24
about active poze tool, there are another problem,,
I can translate rig,, without move pinned node ,, but it can not rotate fee,,
so,, if I hope   y rotate(twist) abdoman2 with keep hand pisiton,,I need to change tool,
I can not do it with active poze tool,,,
then,, I may select left hand and all child node, in scene tab. then use pin tool,  fix rotaiton and translation,,
need many pins for fix hands ,,
but they move,, actually,,even if I keep limits of plevis twist,,
I am now laugh,,because the hand move much with many pins ^^;
now hand positon is different from what they were,,
(so I can not say “pin work well” ^^; it seems break pins)
Image Attachments
Profile
Posted: 06 December 2012 04:49 AM   [ Ignore ]   [ # 8 ]
Active Member
Avatar
RankRank
Joined  2007-01-08
Kitakoredaz, ActivePose has never worked with rotations, it only works with translate. You need to use IK, and its own pins, if you plan on using rotations.
Profile
Posted: 07 December 2012 03:41 AM   [ Ignore ]   [ # 9 ]
Power Member
Avatar
RankRankRank
Joined  2012-03-24
Hi Redave ^^
thak you,, then I knew Active pose can use for only translate.
(I must need to check my english more crefully ^^; when I ask something in this forum ,,)
about the picture,, ,, I rotated with pins by” usuall universal too”
when translate rig “Active pose” work fine, but I have known,  it can not rotate rig,,
But,, DS pins seems not work good when Universal pozing tool.(not select Active pose)
these pins not perfeclty fix the rigs,, I hope , just stop controller.if it can not rotate any more
(over limits of pinned node) .
I wanted to say what you mentioned, so stuck above pics ^^;
Of course I use IK wink  , I checked how it work when check off IK,
just the rig I select can rotate with childres rigs,, it may be useful when I hope so.
Profile
Posted: 09 December 2012 06:58 AM   [ Ignore ]   [ # 10 ]
Active Member
Avatar
RankRank
Joined  2007-01-08
Oh, sorry I didn’t catch that. I don’t have much time lately to read everything properly, and I sometimes jump to a conclusion. I have to say your english is improving noticeably and I can only imagine how hard it must be for you! I do remember when I learned english myself (I’m italian).
Profile
Posted: 09 December 2012 11:51 AM   [ Ignore ]   [ # 11 ]
Member
Avatar
Rank
Joined  2005-08-25
fixme12 - 03 December 2012 03:37 AM
this video show the problem very well…  about hip rotation and locked pin.
http://www.youtube.com/watch?v=zgUg-TJAWC0
daz announced to work on this, so patience….
 Signature
Profile
