Digital Art Zone
save as shader preset
Posted: 30 November 2012 06:48 AM   [ Ignore ]
New Member
Avatar
Joined  2007-12-19
Hi,
I have used a pattern image on a surface and tweaked in the surfaces tab, opacity, displacement etc.
If I save as a shader preset,  the path to the image is c:/users/myusername/Daz 3D/Studio/MyLibrary/ShaderPresets/shaders/myfolder/tile.png
Is there a way to make the path to the image MyLibrary/ShaderPresets/shaders/myfolder/tile.png so i can share it
...or have i got it all wrong
Profile
Posted: 30 November 2012 07:55 AM   [ Ignore ]   [ # 1 ]
Administrator
Avatar
RankRankRank
Joined  2006-03-14
martClut - 30 November 2012 06:48 AM
Hi,
Well, if nothing else the preset file should be clear text so you can just edit it and make it relative.  However, textures rightly belong in runtime/textures/<artistname>/ so moving it there is probably a good plan.
 Signature
My Tutorials and Freebies Index
Profile
Posted: 30 November 2012 08:22 AM   [ Ignore ]   [ # 2 ]
New Member
Avatar
Joined  2007-12-19
Thanks, the shader preset was a .duf file and so i couldn’t open it as readable text to edit.
I saved again as as depreciated .dsa file.
now although it shows the full path in studio, when i opened the file as text, the path is relative so maybe the .duf file is also
Thanks again, carry on!
Profile
Posted: 30 November 2012 09:06 AM   [ Ignore ]   [ # 3 ]
Administrator
Avatar
RankRankRank
Joined  2006-03-14
DUF’s are plain text files as well.
For instance, the start of one I’m working on right now goes…
"file_version" "0.6.0.0",
"asset_info" {
"id" "/Presets/Shaders/beta/AMR SuperAO Skin R2.duf",
"type" "preset_shader",
"contributor" {
"author" "Adam Rasmussen",
"email" "",
"website" "http://adamtls.deviantart.com"
"revision" "2.1",
"modified" "Fri Nov 30 08:18:00 2012"
"material_library" [
"id" "Default",
"transparency" {
"channel" {
"id" "transparency"
 Signature
Profile
Posted: 30 November 2012 10:21 AM   [ Ignore ]   [ # 4 ]
Addict
Avatar
RankRankRankRank
Joined  2011-12-10
Why not just use the Shader Baker, and share those textures?
 Signature
My DeviantArt Galleries
My ShareCG Gallery
OPENSUBDIV Testing and Discussion
3Delight Surface and Lighting Thread
Profile
Posted: 30 November 2012 11:06 AM   [ Ignore ]   [ # 5 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
If it doesn’t open in a text editor, then it’s probably compressed…there should be an option during the save to “Compress files”...uncheck the box.
 Signature
1432 old posts
My ShareCG gallery.
Just because something costs a lot, doesn’t mean it’s the best…
It just means it’s expensive.
Profile
Posted: 30 November 2012 02:32 PM   [ Ignore ]   [ # 6 ]
Power Member
Avatar
RankRankRank
Joined  2008-03-06
You can right-click the compressed .duf and unzip it just like a zip file.  Then you delete the compressed one and add the .duf extension to the unzipped extension-less file, and voila, it can be text edited from then on.  I do this when batch-generating materials for textures.
 Signature
My store at DAZ.
My Deviantart gallery.
Profile
Posted: 30 November 2012 02:53 PM   [ Ignore ]   [ # 7 ]
Member
Avatar
Rank
Joined  2007-06-13
Thanks everyone for sharing how to open the .dufs in a text editior. I was going to have to ask how to do this too, and now I don’t have to. smile
 Signature
Previous post count 1700.
My Store
Profile
Posted: 30 November 2012 05:15 PM   [ Ignore ]   [ # 8 ]
New Member
Avatar
Joined  2007-12-19
thanks all your advice.
I will stick to keeping images/textures in the runtime folder and now know i can text edit the .duf files if needed great
Profile
