Digital Art Zone
Genesis Starter Kit Essentials for Poser trouble
Posted: 30 November 2012 05:54 AM   [ Ignore ]
New Member
Joined  2010-01-02
Hello,
Has anyone encountered trouble trying to load the Genesis Starter Kit Essentials into Poser?  I’ve tried on several occasions and I keep getting an error message “Error changing permissions to 0755 in /Applications/Poser Pro 2012/”
Prior to running the installation this is what I see during the installer in which I’ve selected customize installation.
RuntimeContent Path: /Applications/Poser Pro 2012
DAZ Studio 4.x Files Path (x64): /Applications/DAZ 3D/DAZStudio4 64-bit
It begins to download but then stops with the error message above.  With Retry, Abort, or cancel as the options.
I have all permissions set to me (User). I even went into terminal to manually see if I could change executive privileges but in doing so I’ve received “Folder or Files” not found. After dragging the Poser folder to the terminal.  I need help!
Thanks
Profile
Posted: 30 November 2012 08:11 AM   [ Ignore ]   [ # 1 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Mac? Certainly on Windows at least one of the folders should not be in Program Files, the equivalent of the Applications folder, as the plugin needs to be able to write to the folder as well as to read from it. Try placing one of your content directories in the Documents folder and see if it works then.
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 30 November 2012 11:21 AM   [ Ignore ]   [ # 2 ]
New Member
Joined  2010-01-02
Thanks for the fast response.  I should’ve mentioned that I am using a Mac.  When you say content directory? can you be more specific.
Thanks.
Profile
Posted: 30 November 2012 01:01 PM   [ Ignore ]   [ # 3 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
The folders you have selected in Poser, that show in the Library panel - External Runtimes or External Libraries.
 Signature
Profile
Posted: 30 November 2012 03:26 PM   [ Ignore ]   [ # 4 ]
New Member
Joined  2010-01-02
Hello,
Got it, Thanks. Poser Pro 12 content is in my SHARED folder.  I don’t know how I missed this but everything downloaded ok.
Profile
Posted: 30 November 2012 04:11 PM   [ Ignore ]   [ # 5 ]
New Member
Joined  2010-01-02
Hello Again,
I spoke to fast.  Everything downloaded ok but I don’t know where the files were placed. Essential Starter Kit is not showing up in Poser Pro 2012 \.  Also, I reran the Poser Companion Installer but nothing happened.  Not sure if my paths are correct but I know that my shared content is where I’ve gone before to install other products. I just couldn’t remember where this time.  I use Poser Pro 2010 more frequently.  I need step by step instructions to do this. I will uninstall and wait for a response.  Thanks so much.
Profile
Posted: 30 November 2012 04:57 PM   [ Ignore ]   [ # 6 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Both the Starter Essentials and the Companion Files should be installed to the Poser Pro 2012 Content folder (assuming the name is kept the same on mac as on Windows). Then you should be able to find the files in your Poser library, just like regular Poser content.
 Signature
Profile
Posted: 01 December 2012 05:25 AM   [ Ignore ]   [ # 7 ]
New Member
Joined  2010-01-02
Richard,
Just wanted to let you know that EVERYTHING is working properly and I thank you very much for all of your help.
Profile
