Digital Art Zone
Daz 4.5 unistall problem
Posted: 27 November 2012 11:50 PM   [ Ignore ]
New Member
Joined  2010-03-01
I’m having trouble uninstalling Daz3d on my laptop. It’s an older Gateway ML6720 and it has really bogged down since installing the newest Daz 3d version. I’ve tried to uninstall it by using the add/remove programs process, and Daz3d 4.5 doesn’t show up. When I try to unistall by manually engaging the unistall file in the Daz folders, I get an error msg that says the file is not an executable Win32 file. I’ve even tried to reinstall the program seeing that it runs an uninstall for previous versions, but doesn’t work either as I get an unknown error. Any suggestions?
Gateway ML6720 running Windows 7 with an Intel Pentium Dual CPU T2310 @ 1.46 GHz 1.47Ghz, 1.0GB RAM, 32 Bit OS
Profile
Posted: 28 November 2012 06:22 AM   [ Ignore ]   [ # 1 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
It sounds as if the uninstaller is corrupt. It is C:\Program Files\DAZ 3D\DAZStudio4\Uninstallers\Remove-DAZStudio4_Win64.exe - find that and delete it (you will need admin rights to do that), then reinstall DS and you should be able to uninstall it. Of course the sluggish performance and corrupt uninstaller may be a sign of disc trouble brewing.
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 05 December 2012 08:59 PM   [ Ignore ]   [ # 2 ]
New Member
Joined  2010-03-01
Thanks for the advice. It worked well.
Profile
