Transfering Shader Domains
ghastlycomicghastlycomic Posts: 2,369
If I export a figure to Hexagon, set up shader domains on the model in Hexagon can I use the Transfer Utility to transfer those shader domains to the original figure?
  • KhoryKhory Posts: 3,846
    I'm not sure if it does or not. Why don't you just make the changes in Studio with the polygon group editor?
  • ghastlycomicghastlycomic Posts: 2,369
    Because the polygon group editor is a lot more tedious to work with than editing a figure in Hexagon.
    To each his own. Even though I have been using hex for years I find it easier to do them in studio.
    Setting the viewport, in DS, to 'Wire Texture Shaded' helps some...but I find editing in a dedicated modeller to be faster/more accurate.
