Daz4 Pro. Win7 64. 12G. Dell Precision T3500 Quadro.
Bought Daz a year ago with hopes to use Daz models in my other applications iClone Zbrush Lumion. I’m amazed at the fact that a year later, the same old export errors have not been fixed. Yes I’ve read the most recent relevant posts here.
I still can’t export Obj without the no-texture problem. I still can’t export Collada dae without that dreaded error message. So I tried exporting using FBX, and installed Autodesk convertor as a tedious workaround. Exporting FBX failed, turned out that I don’t have the plug-in.
So I found the FBX plug-in and attempted install and guess what, the FBX plug-in “failed to find the install path”. Yes I tried both 3.x 64bitwin and plain win versions. My Precision system is super stable.
After a year and another round of errors and fact-finding frenzy, I still cannot export Daz models. This is simply crazy.
To top all of the above, documentation on export settings (why those check boxes exist and what purpose) is non-existent. This means checking and unchecking 20 times ten thousand variables before you can be sure this method doesn’t work.
Madness.
Please help. Please. Let me know this is not a waste of my money and time.
