Digital Art Zone
Genesis doesn’t start with skin, and I can’t apply skin.
Posted: 26 November 2012 05:50 PM   [ Ignore ]
New Member
Joined  2012-11-24
I’ve followed the directions exactly, but my genesis doesn’t start out grey - it is transparent.  And every time I apply a skin material, it doesn’t actually follow through.
EDIT: This is for Daz 3d Studio 4.5
Profile
Posted: 26 November 2012 06:00 PM   [ Ignore ]   [ # 1 ]
Active Member
Avatar
RankRank
Joined  2012-08-31
Did you somehow end up saving your genesis figure with a glass shader applied to it?
Profile
Posted: 26 November 2012 06:02 PM   [ Ignore ]   [ # 2 ]
New Member
Joined  2012-11-24
No, I don’t think so - I literally just downloaded this, and just started using it.  I’ve never been able to put on a single one of the skin textures, even though I double click.  It isn’t transparent exactly - more like nonexistent.  I mean, there is an outline of a person, and the shaping is adjustable, but it isn’t actually there.
Profile
Posted: 26 November 2012 06:04 PM   [ Ignore ]   [ # 3 ]
New Member
Joined  2012-11-24
Here is a screenshot of what it looks like.
Image Attachments
Profile
Posted: 26 November 2012 06:15 PM   [ Ignore ]   [ # 4 ]
Administrator
Avatar
RankRankRankRank
Joined  2009-01-22
You see the little Black box in the right corner with the down arrow? That is your Viewport set to Wire Bounding box. Use the Down arrow and pick Texture Shaded. That will fix you right up.
 Signature
My art on DeviantArt and my Project The Primitives a year in the life.
Father of the Stupid threads, find the Stupid you need here.
I may not be worth much but most people tell me my two cents were well spent
Proud Member of the Bald Wizards Club.
Profile
Posted: 26 November 2012 06:16 PM   [ Ignore ]   [ # 5 ]
Member
Avatar
Rank
Joined  2012-09-27
I’m not sure about the setting names, but your display settings in the viewport are not what you need.  See the black 3-D box right next to the grey bar that says ‘Perspective View?  Click on it.  You’ll get a drop-down with several icons.  You want the sphere that looks like a marble with a shadow and everything.  That will display the surface of the selected figure.
Apologies for not knowing the terms - I know someone else will be able to explain it better.  Hopefully this can get you up and running, though.  Good luck!
Edit - ninja’d by Jaderail! smile
Profile
Posted: 26 November 2012 06:23 PM   [ Ignore ]   [ # 6 ]
Member
Avatar
Rank
Joined  2004-04-07
Next to the the words ‘Perspective View’ there is a line drawing of a cube. That shows you’re display is set to wire bounding box.
The downward triangle will open the pull down menu with other display modes, you want the second from the bottom, ‘texture shaded’.
(The orange outline is because you have the Region Navigator active.)
I type very slowly LOL LOL LOL
 Signature
regards
prixat
Profile
Posted: 26 November 2012 06:25 PM   [ Ignore ]   [ # 7 ]
Administrator
Avatar
RankRankRankRank
Joined  2009-01-22
Three great minds, all thinking just alike.
 Signature
Profile
