Digital Art Zone
1 of 2
1
Christmas Tree weirdness
Posted: 26 November 2012 10:11 AM   [ Ignore ]
Active Member
Avatar
RankRank
Joined  2008-05-31
I’ve been playing a bit with this Christmas Tree:
http://www.daz3d.com/shop/yuletide-treasure-tree-2011
Excellent product as such, but there’s something I don’t understand. In the Poser preview it looks like the tree has dropped all its needles on the right side. Doesn’t matter if you rotate it, it’s the same from all angles.
Likewise, if I set up a symmetric light set, the right side of the tree is equally dark, compared to the left. I have to use a rather asymmetric light setup to make the light look somewhat evenly distributed. It only seems to affect the tree, not the props.
Anyone who knows why that is?
I’ve attached some pictures to demonstrate what I mean.
Image Attachments
 Signature
Tools for the DAZ store
Profile
Posted: 26 November 2012 10:19 AM   [ Ignore ]   [ # 1 ]
Member
Rank
Joined  2005-10-16
Are the needles on the tree billboards rather than geometry? I would imagine they are (I don’t have the product) and that can cause issue on how they face the camera and how light and shadow is cast.
EDIT> Not that I don’t fault the maker of the tree. All geometry would be a real system crusher. Not to mention, migraine inducing modeling.
 Signature
Gone.
Profile
Posted: 26 November 2012 10:31 AM   [ Ignore ]   [ # 2 ]
Active Member
Avatar
RankRank
Joined  2008-05-31
jmper - 26 November 2012 10:19 AM
No idea, don’t know what billboards are. But i agree, using geometry would probably be a gigantic task. In any case it’s very detailed and looks very good so I don’t complain… smile
I’ve attached a close up in case that may reveal something:
Image Attachments
 Signature
Profile
Posted: 26 November 2012 10:32 AM   [ Ignore ]   [ # 3 ]
Active Member
Avatar
RankRank
Joined  2008-07-16
Does it change anything if you switch preview mode (OpenGL - SreeD or visa-versa)?  I have seen that before with transparencies. I assume it is not showing up in the render (those lower images are finished renders, right)?
 Signature
VISIT MY ShareCG FREEBIE GALLERY
Profile
Posted: 26 November 2012 10:36 AM   [ Ignore ]   [ # 4 ]
Member
Avatar
Rank
Joined  2007-08-14
Two-sided items showing odd artifacts after rendering
Does this help?
 Signature
These are not the tutorials you’re looking for. Move along.
My old profile
Profile
Posted: 26 November 2012 10:38 AM   [ Ignore ]   [ # 5 ]
Active Member
Avatar
RankRank
Joined  2008-07-16
Billboards are transparent images often used to simulate foliage… a simple example would be a small square UV mapped with a leaf image on a black background… in the transparency setting poser is told NOT to render the black area… the modeler then covers the branch with many similar simple square polygons which will render out as leaves… the simple squares save resources as one does not have to model 6 billion actual leaves.
 Signature
Profile
Posted: 26 November 2012 10:40 AM   [ Ignore ]   [ # 6 ]
Member
Rank
Joined  2005-10-16
***Double post from quoting myself!
 Signature
Gone.
Profile
Posted: 26 November 2012 10:44 AM   [ Ignore ]   [ # 7 ]
Active Member
Avatar
RankRank
Joined  2008-05-31
lordvicore - 26 November 2012 10:32 AM
Well now that you mention it - I’ve just installed Poser 8 and PP 2012 in Win 7 - 64. In Poser 8 and PP 2012 - 32 the preview only works with SreeD, so I set them to use that. It seems however that this setting also affects PP 2012 - 64 (which I’m using here). I’ve now set it back to OpenGL, and this is how the preview looks now, in PP 2012 - 64. No difference in the rendered scene though, as far as I can see.
And yes, the two lower pics of the first three I posted are renders.
Image Attachments
 Signature
Profile
Posted: 26 November 2012 10:44 AM   [ Ignore ]   [ # 8 ]
Member
Rank
Joined  2005-10-16
Wow…gone for a few minutes and the help posts floodgates open.
smile
And looking at the picture you posted, they appear to be billboards to simulate the foliage (as lordvicore indicated). The foliage follows a similar path which would usually indicate a mapped transparency on a flat plane. Usually easier to tell if you observe it in the material room.
***GAAAH I quoted myself!
 Signature
Gone.
Profile
Posted: 26 November 2012 10:47 AM   [ Ignore ]   [ # 9 ]
Active Member
Avatar
RankRank
Joined  2008-07-16
araneldon - 26 November 2012 10:36 AM
Does this help?
Hmmm… thats interesting… I wonder if that is the cause of something I had a problem with once… some weird shadows that would show up in a triangulated polygon…  I googled it and never really fixed the problem and ended up redoing the part.
 Signature
Profile
Posted: 26 November 2012 10:49 AM   [ Ignore ]   [ # 10 ]
Member
Rank
Joined  2005-10-16
Since it is billboards, the only way I found to make the shadow and light look correct sometimes is to do what you did which was using a specialized light to enhance the offending side.
 Signature
Gone.
Profile
Posted: 26 November 2012 10:51 AM   [ Ignore ]   [ # 11 ]
Power Member
Avatar
RankRankRank
Joined  2011-11-25
I really like this tree. IT renders quite well… Thanks for posting about it- although-sorry you are having trouble.
Profile
Posted: 26 November 2012 10:55 AM   [ Ignore ]   [ # 12 ]
Active Member
Avatar
RankRank
Joined  2008-07-16
Looking at that again, it does appear to be made out of billboards… if you look on the left side some of the planes are tilted slightly to and fro.
My amateur guess is that the preview mode does not see the light interacting “properly” and perceives the whole part as transparent.
By the way, you are just asking why this occures (sorta like “is this normal?) and not trying to solve a problem… like you don’t actually need this to appear “normal” in preview mode for some reason… right?
 Signature
Profile
Posted: 26 November 2012 11:01 AM   [ Ignore ]   [ # 13 ]
Active Member
Avatar
RankRank
Joined  2008-05-31
Does this help?
Hey, that seemed to fix it. I checked Normals Forwards for all the needle material groups I could find, and this is how it looks now, with symmetrical lights.  Thanks! smile
Image Attachments
 Signature
Profile
Posted: 26 November 2012 11:05 AM   [ Ignore ]   [ # 14 ]
Active Member
Avatar
RankRank
Joined  2008-05-31
lordvicore - 26 November 2012 10:38 AM
Well here’s how it looks in the material room:
Image Attachments
 Signature
Profile
Posted: 26 November 2012 11:10 AM   [ Ignore ]   [ # 15 ]
Active Member
Avatar
RankRank
Joined  2008-05-31
SereneNight - 26 November 2012 10:51 AM
Yes, it’s an excellent product - have been looking at others (Rendo had one for sale last week) but this is by far the best I’ve seen yet. And the problem is fixed now as you can see.
 Signature
Profile
1 of 2
1
