Digital Art Zone
2 of 2
2
Do the shader lights cast shadows?
Posted: 05 December 2012 12:47 PM   [ Ignore ]   [ # 16 ]
Member
Avatar
Rank
Joined  2007-10-01
Mustakettu85 - 03 December 2012 09:26 AM
dzDistantLightAttribs.dsa
dzPointLightAttribs.dsa
dzSpotLightAttribs.dsa
I found the files and made the changes, but they don’t load for me. When I execute them from the Script Editor I get:
Executing Script…
Script Error: Line 27
ReferenceError: Can’t find variable: Shader
Do I have to do something else with this scripts?
I am running DS 4.5
 Signature
3D Celebrity Lookalikes
Profile
Posted: 05 December 2012 12:54 PM   [ Ignore ]   [ # 17 ]
Active Member
Avatar
RankRank
Joined  2007-01-04
You just edit those files, you use the DUF files in “My Library\Light Presets\DS Defaults” to load them.
 Signature
**shuffles of with a new headache** tongue wink
Profile
Posted: 05 December 2012 01:14 PM   [ Ignore ]   [ # 18 ]
Member
Avatar
Rank
Joined  2007-10-01
Bejaymac - 05 December 2012 12:54 PM
OK, then they work. LOL!
 Signature
Profile
Posted: 05 December 2012 03:52 PM   [ Ignore ]   [ # 19 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
I know it should be a simple matter to make them pop up the dialog box instead of having to hold down the ctl key…but for the some reason I’m not seeing it.  The default choice is set to ‘replace’...which should probably be set to ‘ask’...or at least ‘add’.
 Signature
1432 old posts
My ShareCG gallery.
Just because something costs a lot, doesn’t mean it’s the best…
It just means it’s expensive.
Profile
Posted: 10 January 2013 05:54 AM   [ Ignore ]   [ # 20 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
If you did the manual fix, don’t forget to back up the 3 files, before you upgrade to the latest release.  They will be replaced by the ‘original’ versions…
Or you could, like I did, because I forgot to back them up…do it again. (yeah the files aren’t changed any in this release).
 Signature
1432 old posts
My ShareCG gallery.
Profile
2 of 2
2
