Digital Art Zone
can you use V4/M4 with Daz 4?
Posted: 25 November 2012 07:17 PM   [ Ignore ]
Member
Rank
Joined  2011-09-10
I mean with all the M4/V4 stuff also? or is it only limited to daz 3.
Profile
Posted: 25 November 2012 07:19 PM   [ Ignore ]   [ # 1 ]
Addict
Avatar
RankRankRankRank
Joined  2011-12-10
short answer: yes.  You can use V4, M4, V3, M3, V2, M2, V1, M1 in DAZ Studio 1, 2, 3, 4 and 4.5
 Signature
My DeviantArt Galleries
My ShareCG Gallery
OPENSUBDIV Testing and Discussion
3Delight Surface and Lighting Thread
Profile
Posted: 25 November 2012 07:31 PM   [ Ignore ]   [ # 2 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
Basically, if it is an OBJ based, geometry mesh that is rigged in the Poser ‘style’, it is still usable…and in any version of DS, so far.
If it is a Triax (DAZ’s format) weight mapped figure…it’s usable in DS 4.0 and up.
If it’s a Poser 9/2012 weight map format…it’s not usable.
The first covers the vast majority of items/figures out there (for Poser/DS).
 Signature
1432 old posts
My ShareCG gallery.
Just because something costs a lot, doesn’t mean it’s the best…
It just means it’s expensive.
Profile
Posted: 26 November 2012 05:42 AM   [ Ignore ]   [ # 3 ]
Member
Rank
Joined  2011-09-10
this is the same with the environments, buildings, props etc yes?
Profile
Posted: 26 November 2012 05:48 AM   [ Ignore ]   [ # 4 ]
Power Member
Avatar
RankRankRank
Joined  2009-02-24
Yes, the majority of your models should function perfectly fine in Daz Studio 4.5 aside from the few exceptions pointed out by Wancow.
 Signature
Here be dragons
Profile
Posted: 26 November 2012 06:32 AM   [ Ignore ]   [ # 5 ]
Active Member
Avatar
RankRank
Joined  2008-02-14
I have my DAZStudio directories are pointed to my Poser runtimes and almost everything loads as far as props and figures.  Now depending on the Materials used,  some surface texturing and tweaking might be required to improve the quality of a render.
 Signature
PUBLISHED ARTIST
First Bastion’s Environments here at Daz
Gallery
Profile
Posted: 26 November 2012 12:31 PM   [ Ignore ]   [ # 6 ]
Member
Rank
Joined  2011-09-10
K thanks all.
Profile
Posted: 26 November 2012 02:56 PM   [ Ignore ]   [ # 7 ]
Active Member
Avatar
RankRank
Joined  2009-04-14
I’ve found a few items that don’t like DS4, but they’re older items (4+ years) and usually freebies—anything I’ve bought from the DAZ store still works fine. I’m using M4 and V4 far more than I use Genesis, and I’ve yet to find something for them that doesn’t work in DS4.
 Signature
Truth - It’s the new Hate-Speech
Profile
Posted: 26 November 2012 06:34 PM   [ Ignore ]   [ # 8 ]
Active Member
Avatar
RankRank
Joined  2003-12-06
The only major problems with version compatibility are the other way round — Genesis stuff and anything supplied in the new D|S4 file formats will not work in D|S3 or earlier.
Note that some things are limited to D|S3, some plugins have updated versions which you’ll need to redownload and install, and some plugins were, unfortunately, never updated to D|S4. (Isn’t there a list somewhere of plugin update status?)
 Signature
Gone to Vegas to play poker. Back when I run out of clothes.—Your Muse.
Profile
